Author Topic: jackal center stand?  (Read 2215 times)
Offline Moda253
« on: October 22, 2022, 08:40:16 PM »
I know I have been asking a bunch of questions, but my jackal doesn't have a center stand. And working on it while it is on the side stand is nerve wracking..... Can anyone recommend a decent stand to use that will be stable? Options that won't exactly break the bank would be mucho appreciated.
« Last Edit: October 23, 2022, 09:04:06 AM by Moda253 »
2000 California Jackal (Currently under restoration)
Offline Kent in Upstate NY
Offline Snow Leopard
Re: jackal center stand?
« Reply #2 on: October 23, 2022, 10:59:45 AM »
If I have this wrong, someone please jump in, but I believe any center stand off a Tonti frame bike should work.  I currently have a 2002 Stone (basically same as your 2000 Jackal as I had one for years) and I put a center stand off an old Convert on mine.  It bolted right on and works fine.  These come up on eBay from time to time.
2002 Moto Guzzi Stone
1980 BMW R100RT
2007 Moto Guzzi Breva 1100
Online BMCMOTO
« Reply #3 on: October 23, 2022, 01:55:07 PM »
I think all Tonti frame the centerstands will mount up, differences will be in the height ie; length of the legs. Tire aspect ratio and thus outside diameter, swing arm length etc. willplay into this. I used a later model centerstand on my 2001 Jackal and it was a bit taller, worked well just had to work harder to get it up onto the centerstand.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
« Reply #4 on: October 23, 2022, 07:51:56 PM »
Height can be an issue for sure, as there were many bikes with different swing arm lengths, tire sizes etc. all using the same frame.  On my 2002 Stone, the Convert center stand does not raise the rear wheel off the pavement.  It comes out dead level.  For most maintenance that's fine and easy to rock it up on the stand.  If I need to rotate the rear wheel, I put a 1/2" piece of plywood under the stand.
1980 BMW R100RT
Offline Moda253
« Reply #5 on: October 23, 2022, 08:22:06 PM »
Perfect thanks guys. Snow my bike has a cross pipe between the two header pipes (not sure if that was stock or no) will that play into things?
Online BMCMOTO
« Reply #6 on: October 23, 2022, 08:37:34 PM »
Not a problem, all the later bikes have a crossover or a third muffler sometimes mistaken for a catalytic converter. Make sure you get all the mounting pieces, there are several. Installation is not difficult but can be confusing and maybe a little disorienting because you'll be working upside down.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline Mike Tashjian
« Reply #7 on: October 24, 2022, 07:34:33 AM »
My 02 Stone was missing some parts that did not come with the center stand when new.  My dealer swapped the parts from a bike on the showroom floor.  Seems the factory did not supply every bike with the same bushings and bolts under the motor. That was confusing until the dealer and I looked under a few new bikes at the time.
Offline kidsmoke
« Reply #8 on: October 24, 2022, 08:25:52 AM »
centerstands are priceless on these bikes. But for maintenance another option is a quality front wheel chock. I find that I prefer that even though I've got the centerstand. Really opens things up. Won't help if a wheels got to come off, of course, but shy of that they work well.
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
Offline Moda253
« Reply #9 on: October 24, 2022, 09:30:24 AM »
Well, I am finding it difficult to locate a center stand so it's funny you bring this up. I can find a decent when chock, but I wonder if anyone has a suggestion on a jack for lifting the frame up? That way I could chock the front tire with tie downs to home it in place with a jack to lift the rear wheel.
« Reply #10 on: October 24, 2022, 10:15:12 AM »
This is the one I use. Not as inexpensive as they used to be though.
https://www.harborfreight.com/1800-lb-capacity-motorcycle-standwheel-chock-61670.html
The only issue with it is that it needs to be secured to the floor to get the bike out of it. Read the reviews. Some use a sheet of plywood so the weight of the bike holds it in place. I had a anchor hole in my garage floor. I use a metal rod through the chock and into the hole. Works perfect.
Offline Moda253
« Reply #11 on: October 24, 2022, 11:37:31 AM »
That is the one I was going to get. Nice!
« Reply #12 on: October 24, 2022, 11:50:14 AM »
https://www.harborfreight.com/media/catalog/product/cache/9fc4a8332f9638515cd199dd0f9238da/6/3/63397_I.jpg  I have this style that I used on a Harley and it worked well.  For a Jackal or Stone I think you have make up a wooden or metal part to catch the frame rails and not crush the exhaust.
Offline Moda253
« Reply #13 on: October 24, 2022, 12:51:22 PM »
Interesting. Yeah so it would need a spacer to let the exhausts hang over.
« Reply #14 on: October 24, 2022, 05:06:28 PM »
I thought a few people made a box type adapter with two sides front and back contoured to lift the bike on the frame rails. The box gets secured to the lift and then a strap around the bike, box and lift platform.  I saw it on an old old thread so maybe someone who made or used it will chime in.
Offline Moda253
« Reply #15 on: October 24, 2022, 05:16:51 PM »
Yep I bet I could fashion something even if it is bolted together
Offline s1120
« Reply #16 on: October 25, 2022, 03:02:55 AM »
I have a front chock that I can strap the bike into, and just use a old hydraulic sizor jack I have laying around to lift the other end. I just use a chunk of wood between the jack and bike. Its not pretty but works fine.
Paul B
