Author Topic: High Level Exhaust  (Read 1590 times)
Offline remfanuk
High Level Exhaust
« on: November 10, 2022, 12:22:31 PM »
anyone here know of high level exhaust pipes that are available for my v50 please?  thinking along the lines of a scrambler off the top of my head but maybe even not that high, but something that maybe is upswept?  anyone run a single silencer?  thanks.
Re: High Level Exhaust
« Reply #1 on: November 10, 2022, 12:46:38 PM »
I don't think there is much out there, unless a Stornello V7 would fit, good luck.
« Reply #2 on: November 10, 2022, 01:17:03 PM »
Make a set… :popcorn:
Offline remfanuk
« Reply #3 on: November 11, 2022, 10:29:33 AM »
i would love the equipment...and skills to make one.  i might be better off with something that follows the headers...might be more out there...but is  a very upswept silencer...anyone know of such a thing existing for a 70's v50?
Offline Frenchfrog
« Reply #4 on: November 11, 2022, 10:38:31 AM »
Nothing off the shelf as far as I've ever seen.
The first high level pipes for the small blocks were fitted on the 650/350 NTX's .
Not so easy to find now but in Italy there will still be a few kicking about.
https://partsrepublik.com/en/moto/moto-guzzi/ntx-650-1987/exhaust-unit
Offline remfanuk
« Reply #5 on: November 11, 2022, 01:29:44 PM »
and arent they a whole heap of money!  but, knowing that they fitted those bikes might mean lots of facebook and ebay searches.  thank you.
Offline Frenchfrog
« Reply #6 on: November 11, 2022, 04:00:35 PM »
Go to Subito in Italy...To be honest I think they could be improved by eliminating the first silencer under the side panel which is restrictive and rots really fast.The blending piece for the two header pipes could be better too.As  they are they are probably made to give the most mid range.Some of the similar Baja race bikes had lower  two in ones but with a single mega https://www.youtube.com/watch?v=1OqXTjivPvA
Online nc43bsa
« Reply #7 on: November 12, 2022, 07:12:29 AM »
Could the OEM system from a V65TT be made to fit?
1990 MilleGT
Offline Frenchfrog
« Reply #8 on: November 12, 2022, 08:04:34 AM »
It should but unless you have one you'll have a hard task finding one  in usable condition now.The collector on those tends to rot out badly and  fewer of those bikes were made than the NTX  .
Offline remfanuk
« Reply #9 on: November 12, 2022, 08:53:14 AM »
hmmm...going to have to do some further research on this.  the v65tt is a convoluted affair isnt it.
Offline Frenchfrog
« Reply #10 on: November 14, 2022, 02:00:39 AM »
The NTX doesn't seem to be as good as it could be either.At some point mine will be fitted with a standard road set up to see if there is a better way of doing it.
