Slow rim leak
Topic: Slow rim leak (Read 1364 times)
slowmover
Locked in the arms of a crazy life
Slow rim leak
April 02, 2023, 02:50:20 PM »
What would cause this to develop over the winter? Tires have 10k on them.
Hittman
Hatchling
Re: Slow rim leak
Reply #1 on:
April 02, 2023, 02:55:19 PM »
Probably some slight corrosion on the interior of the wheel which caused the paint to bubble up.
Dharma Bum
Re: Slow rim leak
Reply #2 on:
April 02, 2023, 08:30:50 PM »
Has that happen to my Baby Breva over the winter,too. Took it off, broke the bead on the leaking side, wiped it out and reinflated. Holding air so far.
Tkelly
Re: Slow rim leak
Reply #3 on:
April 03, 2023, 04:01:43 PM »
Time for a new tire.
egschade
Eric S - MGNOC NJ Rep - mgnocnj.forumotion.com
Re: Slow rim leak
Reply #4 on:
April 03, 2023, 05:33:23 PM »
As noted already, break the bead by the leak and check for corrosion. Also check the age of the tire because as also noted, it could be time for a new one.
The elder Eric in NJ
2016 V7 Stornello #394
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
John A
No way to slow down...
Re: Slow rim leak
Reply #5 on:
April 04, 2023, 10:36:12 PM »
Spring is a good time for a new tire anyway….
Slow rim leak
