Author Topic: V7 III 750cc - unknown part function  (Read 1432 times)
Offline Beavis
« on: May 18, 2023, 03:06:21 PM »
Can someone tell the propose of the part #27 ?
Re: V7 III 750cc - unknown part function
« Reply #1 on: May 18, 2023, 04:00:55 PM »
It's purpose is to hold the two shafts (assemblies 12 and 13) which the rocker arms are on.
Offline Beavis
« Reply #2 on: May 19, 2023, 07:18:18 AM »
For sure ? Today I have adjusted my valves and don't see this holding nothing in place , just that part with some screw on it fixed to bare /solid metal. But this is hitting my valve /head cover and making some knocking sound when heats up.
Offline Beavis
« Reply #3 on: May 19, 2023, 07:21:08 AM »
Here's the inside of my valves/head cover.
Online Wayne Orwig
« Reply #4 on: May 19, 2023, 08:00:04 AM »
On the 8 valve models they have the same bit.
The valve cover is 'floating' in rubber gaskets and grommets. That keeps the valve cover grounded in case there is a spark plug arc to it.
Offline tparr
« Reply #5 on: May 19, 2023, 08:31:05 AM »
I have a 2019 v7iii and I noticed this part while inspecting valve clearance. My initial thought ( like Wayne) was a ground path for the valve cover. If it is indeed ratling against the cover perhaps you could put a bit more bend in it.
1969 Moto Guzzi Ambassador "A" model
2019 Moto Guzzi V7III
2013 Ural Gear Up
Offline Beavis
« Reply #6 on: May 19, 2023, 09:06:37 AM »
Solved !!! Many thx for your explanation!
Offline Beavis
« Reply #7 on: May 19, 2023, 09:07:54 AM »
I was thinking the exact same thing . Thx for the reply , will bend it a little.
« Reply #8 on: May 19, 2023, 10:31:53 AM »
For sure ?
Sorry, I was referring to part 6.  I read the diagram wrong.
Offline Beavis
« Reply #9 on: May 19, 2023, 10:46:25 AM »
No worries. You try to help. Appreciate that. 😊
