Author Topic: Piaggio Fails Owners Again  (Read 3965 times)
Offline timonbik
« on: August 29, 2023, 01:08:38 PM »
I've had my V85tt for just over 2 years and have experienced 28000 km of pretty much trouble free riding.  Upon return from the Ontario Guzzi Riders Rally in Ontario Canada I found a light splatter of gear lube on the rear wheel.  Yes gear lube is coming from the drain hole on the driveshaft tube/stay indicating a seal failure on the bevel drive. Yes only 2 weeks out of warranty.  Not a big deal right, just pick up a new seal and change it.  NOT!!!!   On back order until February .     So my bike will be laid up until February.  That's not going to happen.  Sure as hell someone make a seal that will fit.  If not, time to buy a Honda because I've about had it.   Last year my Aprilia was in the shop for 13 mos awaiting waterpump seals for a warranty claim.  Piaggio has to do better!!!
« Last Edit: August 29, 2023, 01:09:37 PM by timonbik »
2008 BREVA 750
2020 V85TT ADV rosso
2016 APRILIA SHIVER 750
2013 VICTORY JUDGE CUSTOM
2013 VICTORY XR CLASSIC
2006 VICTORY V92TC
Re: Piaggio Fails Owners Again
« Reply #1 on: August 29, 2023, 01:28:37 PM »
"Not a big deal right, just pick up a new seal and change it.  NOT!!!!   On back order until February"
I'm not familiar with the final drives on small blocks but like any of my tonti bikes I never ordered the final drive seal from MG, I just drove two miles down the road to Motion Industries,etc. and ordered a seal.
Offline Huzo
« Reply #2 on: August 29, 2023, 01:35:16 PM »
If it’s the pinion seal, then you can easily do it yourself.
Mine went at 10,000 km and I was told that I’d have to wait for my claim to be assessed by Piaggio.
Bugger that..!
I just paid them $70 at my local dealer and they did it while I had a coffee and burger.
Went for a ride that afternoon.
That was 30,000 km back.
« Reply #3 on: August 29, 2023, 01:41:08 PM »
As much as I hate chain maintenance I would definitely be going back to chain if I had to wait that long on a part.
My bike has been at the dealer two months waiting on the front end parts to repair the deer strike damage.
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #4 on: August 29, 2023, 01:58:34 PM »
A. 5 months for a part? 13 months for warranty seal repair? That’s hilariously frustrating. Sorry to read.
B. What is the driveshaft tube/stay? Part of the swingarm? If so, I don’t see a drain hole. Is this a seal you can make yourself?
Online Moparnut72
« Reply #5 on: August 29, 2023, 02:54:11 PM »
When i worked at a NAPA store my fellow long time parts guy had a bearing and seal book. He guarded it like it was a Rolex. It had all the dimensions for a bazillon seals and bearings. It was a NAPA parts book but no longer available. My point is that any business that deals in these things should be able to find one that will work. Rare that it would be a one only part. Also this is the main reason I have two bikes, I don't want to be left high and dry without a ride.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline jrt
« Reply #6 on: August 29, 2023, 03:03:58 PM »
There were a bunch of 2020's that were recalled, right?  If yours falls into that batch then, as I recall, there was some issue with the crown or axle...had a sharp edge that could damage the seal as it was installed.
I had one of them, but it was fixed fairly promptly.
« Last Edit: August 29, 2023, 03:05:50 PM by jrt »
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline timonbik
« Reply #7 on: August 29, 2023, 03:23:23 PM »
Yes mine is a 2020 and there were a number of recalls carried out prior to delivery.   Whether it would be covered by Guzzi is a moot point if they don't have the part.
2008 BREVA 750
2006 VICTORY V92TC
Offline Alfetta
« Reply #9 on: August 29, 2023, 03:36:37 PM »
Which seal - #2 (32x52x7), #11 (38x50x7) or #27 (80x100x10)?
It's likely a common seal, available at any good bearing supplier. #2 should be fairly easy to replace (it was on a '13 V7 Stone anyway), #11 and #27 are a *little* more involved.
« Last Edit: August 29, 2023, 09:15:30 PM by Antietam Classic Cycle »
Offline Alfetta
« Reply #10 on: August 29, 2023, 03:53:02 PM »
found both sizes given on e-bay. and even available in Viton !
Offline Huzo
« Reply #11 on: August 29, 2023, 03:54:58 PM »
It’s not hard.
Online Perazzimx14
« Reply #12 on: August 29, 2023, 04:12:10 PM »
On the face of the seal should be cast three numbers O.D. x I.D. X thickness. Google that or take to any electrical motor rebuild shop and or bearing supply house and, in a day, or three you have a new seal for a fraction of the cost of the OEM,
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline timonbik
« Reply #13 on: August 29, 2023, 04:15:44 PM »
It is number 2 on the parts diagram and is shared with the V9 and V7lll.
Part number is 2B000404..   where would one find the dimensions prior to disassembly.
Nice to have the seal sourced before ripping it apart.
2008 BREVA 750
2006 VICTORY V92TC
Online RinkRat II
  • Lake Powell AZ
« Reply #14 on: August 29, 2023, 04:45:44 PM »
    Cadre Cycle shows it for $21.00 US. Doesn't say if they have it or not.   https://cadrecycle.com/
    Paul B :boozing:
Offline timonbik
« Reply #15 on: August 29, 2023, 04:54:39 PM »
    Paul B :boozing:
Will call them tomorrow, however everyone shows it and when they check on availability. "backordered"
2008 BREVA 750
2006 VICTORY V92TC
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #16 on: August 29, 2023, 05:02:17 PM »
Try putting the seal part number into a search engine to see if you can get the seal dimensions, then get a replacement seal from an industrial supplier.  Piaggio is buying their seals from an industrial supplier, you might as well do the same.
If not, call around to some MG dealerships to see if the mechanics will give you the dimensions.  Might cost you a case of beer, but I would gladly pay that.
If not, tear it apart and measure it.
Good luck.
« Last Edit: August 29, 2023, 05:06:39 PM by SIR REAL ED »
2019 Beta EVO 250
Offline bacongrease
« Reply #17 on: August 29, 2023, 07:33:26 PM »
   This is why there are so many Hardleys.
Get a Sportster...
 :bike-037:
Backup....
« Last Edit: August 30, 2023, 07:44:52 AM by bacongrease »
Offline ridingron
« Reply #18 on: August 29, 2023, 07:58:44 PM »
Try this place. Not sure where "de" in address refers to, Germany? Says they're in stock but who knows?
https://www.sd-tec.de/en/gasket-ring/item-1-2B000404.html
« Last Edit: August 29, 2023, 07:59:34 PM by ridingron »
« Reply #19 on: August 29, 2023, 08:39:58 PM »
timonbik: Sent you a PM (or two).
« Reply #20 on: August 29, 2023, 09:15:56 PM »
32 x 52 x 7
« Last Edit: August 29, 2023, 09:18:54 PM by Antietam Classic Cycle »
Offline ridingron
« Reply #21 on: August 30, 2023, 12:32:17 AM »
Search for the seal by the dimensions given has numerous sources.
  32 x 52 x 7 seal
  https://www.google.com/search?q=32+x+52+x+7+seal&rlz=1C1BLWB_enUS593US637&oq=32+x+52+x+7+seal&aqs=chrome..69i57j33i160l2j33i22i29i30l4.8792j0j15&sourceid=chrome&ie=UTF-8
Anyone have it in stock is the question.
« Last Edit: August 30, 2023, 12:34:16 AM by ridingron »
Offline Huzo
« Reply #22 on: August 30, 2023, 05:12:59 AM »
Denmark ?
Offline Dirk_S
« Reply #24 on: August 30, 2023, 07:14:11 AM »
Just for clarity and future reference, I don’t see the V7 III popping up as a compatible model for this seal, just the V9, V85TT, and V7 E5; essentially, all the 850 models. They have different style swingarms, driveshafts, and final drives from the older small blocks. The V7 III still shares its respective parts with the older models (V7 II and back)
« Last Edit: August 30, 2023, 08:02:24 AM by Dirk_S »
Offline SIR REAL ED
« Reply #25 on: August 30, 2023, 07:56:40 AM »
Shows Sept.1st to my location. $9.12 +
https://www.motion.com/products/sku/07330846?utm_source=google&utm_medium=cpc&utm_campaign=oil_seals&utm_content=oilseals_dynamic&gclid=Cj0KCQjw0bunBhD9ARIsAAZl0E2On4IAzaMa4nuLZf7t6KytEjnRq7mxsbDLlfMFLE8GzuLIfvW2mZkaAtAaEALw_wcB
NINE DOLLARS!!!!  (Guzzi Content)
I REMEMBER WHEN YOU COULD BUY A BRAND NEW MOTORCYCLE FOR NINE DOLLARS!!!!   :wink:
Wouldn't it work better if you slapped a Piaggio label on it and charged $90?
« Last Edit: August 30, 2023, 07:58:09 AM by SIR REAL ED »
2019 Beta EVO 250
« Reply #26 on: August 30, 2023, 08:55:54 AM »
Denmark ?
Seems to be Stein-Dinse, or a division thereof. Located in Germany.
