OXYGEN SENSOR
Topic: OXYGEN SENSOR (Read 1907 times)
Spuddy
Best Thing About A Mind Is Being Able To Change It
OXYGEN SENSOR
September 11, 2023, 02:20:09 PM »
Anybody replace the o2 sensor on an 8v 1200 engine? My ‘13 Stelvio NTX still seems to be running rich despite a FI sync and air screw adjustment by a Guzzi Guru.
No warning light or codes but I’m gunna gamble on a new o2 sensor. Any experiences or brand recommendations?
Spud
'13 Stelvio NTX
'07 California Vintage
'01 W650
lucian
Re: OXYGEN SENSOR
Reply #1 on:
September 11, 2023, 04:20:51 PM »
Which "air screw exactly was adjusted? The air bleeds on the bottom of the tb's? Hopefully not the sacred screw sealed with yellow paint on the left hand tb. Are there any mods to exhaust or air intake? Are you running a factory fuel map or other? Have you checked for any stored fault codes with a diagnostic tool like guzzi diag? An open loop map would eliminate the need for 02 input and result in a better running machine. Engine temp and air pressure sensors could also be a cause for bad trim input. Beetle at Griso . org is your guy.
Global Moderator
Re: OXYGEN SENSOR
Reply #2 on:
September 11, 2023, 05:41:58 PM »
+1 on the Beetle mapping.
Spuddy
Re: OXYGEN SENSOR
Reply #3 on:
September 11, 2023, 05:55:25 PM »
I didn’t mess w anything. Jason W out of Duvall WA synced it and got the idle down via Guzzu Diag. Like I said no fault codes, present or past.
At minimum I’m gunna pull the oem sensor and at least inspect it.
Spud
'13 Stelvio NTX
'01 W650
Spuddy
Re: OXYGEN SENSOR
Reply #4 on:
October 15, 2023, 05:19:11 PM »
I got two Warner sensors. Hope to have them in before it snows to see if they make any difference. But my Calvin is taking up too much time.
Spud
'13 Stelvio NTX
'01 W650
nc43bsa
Re: OXYGEN SENSOR
Reply #5 on:
October 15, 2023, 06:13:28 PM »
Is it a little rich or really really rich?
1990 MilleGT
guzzisteve
"Just Ride It"
Re: OXYGEN SENSOR
Reply #6 on:
October 15, 2023, 06:13:52 PM »
I take it it's all stock by what you are posting, O2 sensors do go wacky. I would check the temp sensors also with the figures in the service manual for accuracy. GuzziDiag will tell you the info on what they say or check w/meter.
Spuddy
Re: OXYGEN SENSOR
Reply #7 on:
October 16, 2023, 02:19:56 PM »
Thanks, Steve
Spud
'13 Stelvio NTX
'01 W650
Wayne Orwig
Re: OXYGEN SENSOR
Reply #8 on:
October 17, 2023, 08:06:29 PM »
What is the color of the spark plug ceramic after an engine cut off at speed?
OXYGEN SENSOR
