My 1200S Frankenstein bike is using a Power Commander V with a broad band O2 sensor and a aftermarket fuel map. The fueling is too rich as is. I managed to get the fueling tolerable using the infield fuel adjustment but it still isn't as good as it should be.
Does the AFR settings provide a upper limit on the fueling and how much variance cell to cell on the mapping tables are acceptable?
I have played with mapping and made some improvements but I am really just bumbling around with limited knowledge of what I am doing.
Attached is the Fuel map that I started with
