Author Topic: Fuel pump assembly  (Read 1473 times)
Offline bacongrease
Fuel pump assembly
« on: March 04, 2024, 09:36:32 PM »
2004 Stone Touring.  I could use the whole unit,  I don't see any available for that specific model.   Any idea if the other ones listed on ebay would work.  Default says they do not. However these are not very reliable.  But from all appearances they look very similar.  Some identical.   Norge, Breva, etc.  Mine leaks thru the wiring hole, and all kinds of goop  (PermaTex, Seal-All) just will not stop the leak.  The 6 bolt holes appear to be the same. I can't see the electrical connections well enough. The only difference is the (quick release) appears different on some.
« Last Edit: March 04, 2024, 09:58:33 PM by bacongrease »
Offline moto-uno
Re: Fuel pump assembly
« Reply #1 on: March 04, 2024, 10:04:26 PM »
  What ever you decide upon , please make sure it has the same fuel pressure as the OEM , even 5psi less can make for poor running . Peter
« Reply #2 on: March 05, 2024, 08:20:06 AM »
Maybe something from this site will work. Convert back to external pump, might have to swap out tank.
https://ca-cycleworks.com/efi.html
Offline n3303j
  • Ron Cichowski
« Reply #3 on: March 05, 2024, 06:57:25 PM »
Thought you'd want a pump with same pressure or higher (and sufficient volume). The regulator would drop the pump output pressure to the pressure required at the injector.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #4 on: March 05, 2024, 08:34:23 PM »
That’s what I’d look for, as well as its physical size and fitting similarities.
