You are applying the pressure to compress the springs against the pockets in the flywheel. Flywheel presses on the crankshaft. Crankshaft absorbs the thrust.
As one person already pointed out, it can sometimes be challenging to find neutral when the engine is running (on my 2016 V7 II it is). Engine off no problem. Do I want to fiddle around endlessly at a stop light looking for neutral? No. Do I want to shut the bike off at a stop light? No. So if it doesn't flip into neutral after one or two tries, I just leave the clutch pulled in. Not a problem.
No one has mentioned that disengaging the clutch places the thrust bearing at the front of the crankshaft under load. Wonder how long that bearing lasts?
Enter the Hendon ShuffleHendon is where the police motorcyclists are trained in the UK and I believe that this is still currentEssentially when stopped you have the bike out of gear and held stationary with the foot brake and left foot on the groundTo pull away you hold the bike with the hard brake, switch feet (hence the shuffle) to engage the gear and pull awayhttps://longrider.co.uk/blog/2012/08/25/starting-stopping-and-thoughts-on-the-hendon-shuffle/
Neutral doesn't save the clutch, just the throw out bearings (and a bit of your wrist).
Why not fix the actual problem - i.e. adjust the clutch so you can find Neutral.
