I am looking at replacing some seals from a 1950's scooter I picked up. These seals are a bit different from today's seals but was wondering is this a common item that can be interchanged with current shaft seal technology?
I figured as long as the OD and thickness is roughly the same they should press fit right into the cases with no issues.
Also what type of beaings are these that have the races collapse onto the bearing ring. So that the shaft is supported between two cases?
