Author Topic: 1974 850T Clean oil leaking from bellhousing  (Read 3988 times)
Offline sanderoudev
  • Professional amateur
  • Ride to live, live to ride
« on: February 18, 2025, 07:19:18 AM »
Hi,
I just introduced myself in the introduction subforum.
My name is Sander and i'm from the Netherlands.
I own a 850T from 1974 which i'm currently rebuilding.
The engine and transmisssion i did not take apart, because the previous owner did rebuild them. (proof on paper)
The last year the engine didn't turn over but last week there was quite a puddle of clean oil underneath the bike.
It seems to be coming from the cutout between the engine and tranmission, the slot that is i guess for letting oil out when there is a leak.
Next week i'm going to split the engine and tranmission to inspect and replace all neccesary parts.
I'm going to crab the frame, but i have a couple of questions;
1. What tools do i need to remove the flywheel, clutch and seals/bearings.
2. While i'm in there, what parts should i replace as a precaution?
3. Are there any tips / tricks involved ?
Regards,
Sander
Offline paulbricey
Re: 1974 850T Clean oil leaking from bellhousing
« Reply #1 on: February 18, 2025, 08:42:01 AM »
What does the oil smell/feel like ?? Gear oil, engine oil (usually not clear, but can be if it's not been run), or hydraulic fluid (unlikely but who knows where brake fluid could be leaking from & too ?).
Riding to live
Offline jhem68
« Reply #2 on: February 18, 2025, 08:53:31 AM »
Start here for all the possible sources of an oil leak at the bell housing weep hole
https://www.thisoldtractor.com/moto_guzzi_loopframe_engine_oil_leaks_from_the_bell_housing.html#google_vignette
After the transmission and clutch are removed, I would recommend doing the fixes for all the possible sources of eigne oil leaks while it is apart even if you have thought you had a clear indication of the source. You wouldn't want to find it still leaking after putting it back together. BTDT!
I know this link is referencing a loop frame, but the same applies to your 850T. Lot's of info on This Old Tractor site.
John H
« Last Edit: February 18, 2025, 08:58:59 AM by jhem68 »
Offline sanderoudev
« Reply #3 on: February 18, 2025, 08:56:58 AM »
It has no smell, or my smell is not to great. It feels like 'thick' oil so not likely to be brake fluid.
Engine has been run, and the dipstick also shows brown oil. Likely to be atf oil.
« Reply #4 on: February 18, 2025, 10:00:47 AM »
If you enter what you want in the search box in upper RH corner of page you will get all sorts of answers, try a search.
Offline moto
  • Fear the deer!
« Reply #5 on: February 18, 2025, 12:58:22 PM »
850Ts don't use ATF. Sometimes ATF is introduced into the bell housing to free stuck clutch plates. I would check the levels of your different oils and ride it some more. Maybe the ATF flow will be exhausted.
850 T-3
Griso 1100 corretto
Offline sanderoudev
« Reply #6 on: February 18, 2025, 01:21:03 PM »
Sorry what i meant was gearbox oil.
Overnight it lets about 2/3 drops on the floor.
So driving it doesn't seem to be the wise thing to do.
Offline moto
  • Fear the deer!
« Reply #7 on: February 18, 2025, 02:05:14 PM »
Thanks, that makes more sense. Best to follow your plan, then.
850 T-3
Griso 1100 corretto
« Reply #8 on: February 18, 2025, 10:06:55 PM »
Gearbox oil could be clutch pushrod seals. If whoever rebuilt it reused the original tight fitting hard plastic tube, then no wonder. If they used the "upgrade" rubber cones, I've had those leak as well. That's why I use the six o-ring stack now.
Unfortunately, the clutch is likely oil fouled now.
Offline moto-uno
« Reply #9 on: February 18, 2025, 10:29:50 PM »
  ^ +1 For what Charlie said ! And don't forget the "O" rings under and at the inner edge of the splined input shaft ( the ones the clutch friction plates ride on ) .
Offline sanderoudev
« Reply #10 on: February 19, 2025, 12:51:54 AM »
I will look into this. No matter what the box should come of then.
Thanks you, will check this aswell!
Offline TOMB
« Reply #11 on: February 19, 2025, 08:50:01 AM »
Note
The two lowest bolts on the rear main  bearing are through bolts directly into the crankcase and may also leak due to lack of sealant or dried out sealant.
The rear main gasket is probably  dried out.
Also the vent pipes especially  the one o'clock position gasket dried out.
The large   vent pipe that goes to the breather box the hose clamps could be loose which would allow oil to drip outside  between the hose and large pipe into the bell housing as the pipes both of them float where they enter float and don't seal as they pass through.
TOMB
« Last Edit: February 19, 2025, 08:53:51 AM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #12 on: February 19, 2025, 12:52:34 PM »
This vid may help, besides what Tomb said, note the sealant on the cam plug
https://youtu.be/7PyvYjdPUr8?si=R-ZjMJ10kYLWYjW7
Offline sanderoudev
« Reply #13 on: February 21, 2025, 09:37:45 AM »
Well after 2,5 hours the box is out.
It's leaking from the pushrod.
The plates are contaminated as well.
The starter gear looks rather nasty. Is it necessary to replace?
And the seal in the output side als leaks. Meaning there is oil inside the swingarm.
If I clean this up, it should be ok? Or should I replace the bearing in the swingarm now?
Offline jcctx
« Reply #14 on: February 21, 2025, 04:19:48 PM »
If clutch friction plate not to worn brake cleaner will most likely make it work normally. Or, it might pay to replace while in there anyway????
« Reply #15 on: February 22, 2025, 08:09:53 AM »
You will need to take off nut on output shaft & change seal. Get brown ones they seal better than blue ones.
There is a speedo metal ball in a slot after nut comes back, make sure you catch it w/magnet.
That starter ring gear looks OK to me.
If you take off the imput hub on trans you can use it to alien the plates on assembly. There is also a seal & orings there too.
Offline Moparnut72
« Reply #16 on: February 22, 2025, 09:37:33 AM »
Replace the clutch disc, if it is oil contaminated there is no way to get it out. I had brake pucks that suffered from leaking fork oil. I cleaned with brake cleaner also, no go. I replaced them. I don't think you want to go through this a second time. A few bucks for a new disc is a lot cheaper than tearing it all apart a second time.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline sanderoudev
« Reply #17 on: February 23, 2025, 09:49:53 AM »
Thank you, i will see if i can get some Viton seals here.
kk
Yes i will replace the disk. Don't want to be in here a second time.
