Looking for advice on 17' V9 Bobber
Topic: Looking for advice on 17' V9 Bobber (Read 1890 times)
MotoG5
March 11, 2025, 05:18:05 PM »
Going to have to pull the wheels on the 2017 V9 Bobber to install a new set of tires. Anyone here done the wheel removal have any tips, tricks or things to look out for? Any input will be appreciated.
Nebraska MGNOC State Rep
elrealistico
Gosling
Re: Looking for advice on 17' V9 Bobber
Reply #1 on:
March 11, 2025, 06:06:58 PM »
some kind of glue/grease/RTV to hold the cush rubbers in when you try to put the tyre back on helps a lot on my V7.
2018 V7III Special
1978 T140V Bonneville
2004 EV Touring
Kev m
Not your normal Hombre
Yo from Medford, NJ
Reply #2 on:
March 11, 2025, 06:43:54 PM »
Yeah, it's pretty straight forward.
It can help when removing the rear tire if you have some height (lift the rear or a drop out plate on the lift).
Also you'll want to remove/relocate the caliper and bracket.
The cush rubbers are the worst part but they are not that bad if you maximize clearance around the pumpkin before trying to align the hub (that's where the caliper and bracket moving out of the way really helps).
Just ask if you run into trouble.
guzzisteve
"Just Ride It"
Reply #3 on:
March 11, 2025, 07:32:09 PM »
It will help if you flip the LH shock up horizontal. Some here even pull the rear drive off swingarm.
faffi
Bloody foreigner from Norway
Reply #4 on:
March 12, 2025, 05:42:45 AM »
The rear is a bit of a faff - the Yamaha solution found on most of their shaft drive bikes are far superior, as is that of the other Japanese makers. Removing and installing the front wheel on the Bobber could not be made any easier.
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Moparnut72
Reply #5 on:
March 12, 2025, 09:38:49 AM »
Letting the air out of the tire will give a tickle more space to maneuver the wheel. I hadn't thought of removing the rear drive. I will give that a look the next time I change the rear tire on my V7.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
