Well I may have found the correct hinges with Google images search.
The name they go by is Art Deco style hinges or Hoosier style hinges.
This is the antique one listed as "Vintage Cabinet Art Deco Chrome Hinge":
This is a new one listed as "3/8" Off Set Sellers Cabinet Hinge NICKEL Hoosier Wilson Solid Brass":
The antique one is made 2 ways, flat and 3/8 offset. The offset on THE SHORT END is what was originally used. There are new hinges made that look like the antique ones, but the offset is on the long end.
Also, if you look closely at the new and old pic, you will note that the long end of the hinge is mounted under the hinge pin on the new one and level with the hinge pin on the antique. The originals that I have are under the pin. I do not know if it will make a difference, maybe the level to the pin may work better?
