Author Topic: Dellorto VHB rebuild  (Read 2423 times)
Offline Turin
« on: April 06, 2025, 05:33:04 PM »
It's been 20 years since I cleaned these carbs. (the ambo sat for a few years). Last time, I didn't do the best job and I found 2 instances of cobbing.
Here's the question... Do the idle screw and the mixture screw get O-rings and gaskets? None were present but I see them on the exploded parts diagram.
1985 Sidlow Guzzi
Re: Dellorto VHB rebuild
« Reply #1 on: April 06, 2025, 05:36:19 PM »
None that I have seen or replaced.
« Reply #2 on: April 06, 2025, 06:12:09 PM »
I vaguely recall that there was a Delorto service bulletin that said you could use them on the mixture screw if you wanted. Just add the washer and and o ring,the mixture screw remained the same.
« Last Edit: April 07, 2025, 08:48:32 AM by John A »
« Reply #3 on: April 06, 2025, 06:57:30 PM »
None of the Guzzi VHBs ever came with them.
Offline Turin
« Reply #4 on: April 06, 2025, 07:16:55 PM »
Then I'm not crazy. Thanks!
1985 Sidlow Guzzi
« Reply #5 on: April 06, 2025, 09:08:27 PM »
That’s a bold statement from someone that rides a Guzzi!  :grin:
« Reply #6 on: April 07, 2025, 03:42:18 PM »
 Yep, I first saw them on PHF’s. You can put them on VHB’s, it’s optional. As I recall there were no other changes needed to use them. There were two reasons, one was it could pull air in around the mixture screw and to help the screw stay in place. I’ve never had one move out of adjustment, maybe on a dirt bike it would make sense.
