Unless someone changed the ECU, it's a 15"M" not "RC". RC was Calvin and some others IIRR. My '04 is 15M.EDIT: Also when your using the up/down load programs, the fuel pump should NOT be heard when you start the process. If it does come on, you likely have the wrong "port" selected in the up/down program or the wrong up/down program for your ECU. If you going to up a new map, I would suggest as the folks at GD do, download and save the original before you up in case you need to go back. It's also a good idea to have the bike on a charger and make sure you laptop or whatever is fully charged.Tom
Another post you said 15RC and another you said you had an O2 sensor on it. Did someone modify your bike?
But on the Norge the ECU is a IAW 5AM ! not 15M You have to use IAW5xReader_V0.28.e xe and IAW5xWriter_V0.24.e xe to read/write the ECU.
The Reader and Writer disable the fuel pump.When I wrote the wrong port, GD and the read/write programs have a option of what Com port to connect to. If the cable is connected to the computer on com1 and the software is looking at com2, they can't talk. You need to tell the software com1.Tom
CO trim, yes. Throttle self learning, no."Choke" lever on the handlebar is nothing more than a lever to hold the throttle open a bit while it warms up. You could do the same by turning the throttle grip with your hand.This bikes fueling system and ignition is way different than the Norge.To adjust the fuel trim you use GD, not the reader/writer. I would use GD to see what the fuel trim number is. You want about "0", maybe +10 to +20. It might even like a -10?Tom
