Author Topic: Measuring straightness of triple tree clamps.  (Read 210 times)
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« on: January 08, 2026, 04:30:17 PM »
I bought a set of used triple trees from a V7 E5 off eBay to put on my V9 (the V7 E5 triples are the same part number as V7 III triples, btw). Obviously coming from a parted out bike, there’s always the risk that the triples could be damaged due to whatever collision this bike experienced. How do I go about measuring for straightness? Do I have to install the triples, slip in the forks, and measure at various points on the forks, or can I somehow measure for straightness with the triples off the bike?
Re: Measuring straightness of triple tree clamps.
« Reply #1 on: January 08, 2026, 04:50:28 PM »
First, test your tubes for straightness. This can be done by laying the tubes against each other “head to toe” so to speak and see if they touch at all points along their length.
(Head to toe was a cleaner way of describing the juxtapositioning of the forks relative to each other…) :wink:
Anywayyyy…
Once you’ve determined that the staunchions are straight, slide them into the lower triple and clamp them with the pinch bolts.
You will be able to sight across one leg and easily determine if it is parallel with the other. The most minute twist in the triple will be easily discernible using this method.
Do the same with the top triple.
« Last Edit: January 08, 2026, 08:07:17 PM by Huzo »
Offline n3303j
  • Ron Cichowski
« Reply #2 on: January 08, 2026, 05:39:36 PM »
Used this procedure when I was riding BMWs.
Duane was good at making things work correctly.
https://w6rec.com/duane/bmw/fork/chapter1.html
It's got most all you want to know about fork truing.
There are a bunch of pages. Use arrow at bottom of chapter to advance or return.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
