Author Topic: Recommend Rod Bearings?  (Read 971 times)
Offline neetones
« on: January 15, 2026, 10:54:34 AM »
1969 Ambassador. Crank is still within original spec, existing bearings are standard.
What do you recommend purchasing? I'm seeing a lot of generic bearings out there. Are they any good?
1969 Ambassador
2022 V7 850 Centenario (sold)
Re: Recommend Rod Bearings?
« Reply #1 on: January 15, 2026, 12:36:44 PM »
« Reply #2 on: January 15, 2026, 01:09:23 PM »
Looks like chrome specks embedded in the bearing. I’d say you caught it in time. I’d pull the crank to clean out the sludge trap and with a magnifying glass pick out any visible chrome bits from the mains and cam bearing surfaces. I use a needle . It’s a ’ feature’ of chrome plated aluminum cylinders. It eventually comes off and it’s hard so when it embeds in bearings, it grinds away. One of the reasons is that the expansion rate between the chrome and the aluminum is different so it loses its bond.
Offline neetones
« Reply #3 on: January 15, 2026, 01:24:10 PM »
This engine is such a puzzle. Horribly filthy oil, pitted lifters, cam needs resurfacing, etc...but then the sludge trap is completely empty. Gilardoni cylinders.
So someone did some work in here, but they didn't go all the way.
1969 Ambassador
Offline neetones
« Reply #4 on: January 20, 2026, 03:02:37 PM »
So it looks like I need a crank regrind and 1st undersize bearings (rod and mains).
Anyone have a recommendation for someone who can properly grind Guzzi cranks and check clearances, etc?
Thanks!
1969 Ambassador
« Reply #5 on: January 20, 2026, 05:12:26 PM »
Thanks!
Grind the crank to the specs. published in the factory manual, yes. It would be up to you to check clearances.
https://www.facebook.com/Griffithprecision/
https://www.thisoldtractor.com/mg_manuals/workshop_manual_700_750.pdf
Online Turin
« Reply #6 on: January 20, 2026, 05:17:37 PM »
I sent my crank to these guys for polish and balancing for lighter pistons and rods. I also used standard guzzi crank bearings.
He's a one man shop with his wife working the phones.
 https://marinecrankshaftinc.com/
« Last Edit: January 20, 2026, 05:18:34 PM by Turin »
1985 Sidlow Guzzi
Online cliffrod
« Reply #7 on: January 20, 2026, 05:36:22 PM »
Decades ago when I was young & knew no better (and when many people thought worrying about failing chrome was overreacting)  I only did new girladoni cylinders & pistons on my bike and hit the road.    It wasn’t long before the entire engine had to be completely rebuilt, exactly like your engine needs to be rebuilt.
My btdt $.02 of advice- If you plan to keep the bike, it doesn’t matter what someone before you did or didn’t do.  Do it $$$$ all and do it right this time or don’t waste the time & money to do anything at all.
Offline neetones
« Reply #8 on: January 21, 2026, 11:40:29 AM »
So it looks like I have 83mm Gilardoni cylinders but original Guzzi pistons!?
Am I good running these or do I need to source new pistons/rings?
It looks like the rings are steel/chrome and probably incorrect for the Nikasil cylinders.
« Last Edit: January 21, 2026, 11:53:56 AM by neetones »
1969 Ambassador
« Reply #9 on: January 21, 2026, 01:55:17 PM »
Is the Gilardoni name cast into them? If not, then they're likely original cylinders that have been replated.
Probably best to replace the rings.
Offline neetones
« Reply #10 on: January 21, 2026, 02:18:51 PM »
Gilardoni name is cast into the cylinders. Nikasil looks to be in great shape.
1969 Ambassador
« Reply #11 on: January 21, 2026, 02:33:51 PM »
Original pistons were "Mondial", Gilardoni pistons aren't usually marked. Any name cast into the underside of yours?
Offline neetones
« Reply #12 on: January 21, 2026, 05:00:03 PM »
Ah, yes, the pistons are marked Mondial and Guzzi.
1969 Ambassador
« Reply #13 on: January 21, 2026, 05:03:53 PM »
Odd that someone mixed o.e. pistons with aftermarket cylinders. I guessing probably because Ambassador sets haven't been available for quite some time, so they used cylinders from Eldo kits and their o.e. pistons. As long as the piston-to-cylinder clearances are correct that shouldn't be a problem.
