Author Topic: Loop Alternator Conversion  (Read 5928 times)
Offline wirespokes
« on: May 24, 2026, 08:43:50 PM »
Looks like I'm a little late to this party.  :cry:
Greg Field used to sell the mounting brackets and I guess a whole kit including alternator. Other places used to sell the mounting bracket, but not now. Looks like I'll have to make the bracket myself.
Are there drawings anywhere I could access? Any idea where I could locate the bracket new or used?
Re: Loop Alternator Conversion
« Reply #1 on: May 24, 2026, 08:57:29 PM »
Harper's has them.
https://harpermoto.com/products/12700300m-loopframe-alternator-bracket-only
Joe Walano "The Guzzi Doctor" may also have some left to sell.
I installed one on my police Eldo and the hole for the oil line was too high, so unless they've moved it, that needs to be modified. Edit: one other thing I did: removed the powercoating on the underside so there would be a good ground to the case, and removed it also where the alternator contacts the bracket for the same reason.
Greg Bender sells a harness. I bought a Nippon-Denso copy alternator on ebay.
https://www.ebay.com/itm/306059867870
« Last Edit: May 25, 2026, 08:44:55 AM by Antietam Classic Cycle »
« Reply #2 on: May 24, 2026, 11:35:10 PM »
Charlie,
Did the generator light work correctly with the alternator that you linked??
I have a Denso copy for a spare that the light does not work right.
« Reply #3 on: May 25, 2026, 08:32:39 AM »
Charlie,
So far it is.
Online Perazzimx14
« Reply #4 on: May 25, 2026, 08:39:28 AM »
I built my own alternator bracket out of 1-1/2" flat stock and 1/4" pipe. I'll have to search around to see if I have any pictures. The bracket looked sort of like the USS Enterprise
« Reply #5 on: May 25, 2026, 08:54:03 AM »
When I bought my current ‘71 police Ambo, the seller had a new Field/Nolan Alt kit still in the box.  I didn’t hesitate to buy it from him to add to the refurb (to include new cylinders) at Charlie’s place.
« Last Edit: May 25, 2026, 08:59:08 AM by Cam3512 »
« Reply #6 on: May 25, 2026, 10:50:11 AM »
If it's working, it will keep working. The copy I have did not make the light work correctly out of the box. I don't remember the exact issue, I think the light stayed on even though it was charging?? BTW police dash on both bikes with the pull knob for ignition.
Might have to pick up one of those. Thanks!
Offline wirespokes
« Reply #7 on: May 25, 2026, 06:51:04 PM »
I'm considering making my own bracket - not quite ready to spend $140 plus shipping on one.
« Reply #8 on: May 25, 2026, 09:41:06 PM »
How much is your time worth? Figure in the cost of materials as well.
Here are some mounting ideas: https://www.thisoldtractor.com/moto_guzzi_loopframe_alternator_conversion.html
Offline JoeW
    • The Guzzi Doctor
« Reply #9 on: May 27, 2026, 01:13:19 PM »
Harper's has them.
Charlie, That isn't one of my conversion brackets
Joe Walano
Offline bigbikerrick
« Reply #10 on: May 27, 2026, 01:41:40 PM »
Charlie, do you use the same pulley that comes on the ebay alternator?
thanks
Rick.
Offline wirespokes
« Reply #11 on: May 27, 2026, 01:55:30 PM »
Charlie - yeah, I know - how much is my time worth? And how much is my money worth? I do enjoy making stuff, but on the other hand, I've already got more than enough projects. So I really need to prioritize. This project isn't going to be back on the road any time soon, so there's plenty of time to make a decision. And, I guess, the condition of the generator will factor in as well.
Joe - would you have any brackets left for sale? If not, plans or drawings?
« Reply #12 on: May 27, 2026, 03:27:52 PM »
Yes, I know it isn't, it's a Harper's bracket, as I wrote just above where I referenced yours.
thanks
Rick.
Yes, no need to change it.
Offline JoeW
    • The Guzzi Doctor
« Reply #13 on: May 27, 2026, 05:15:06 PM »
I have 4  left, one is powder coated three are raw steel. They are 125.00 each plus 25.00 shipping in the US.
Joe Walano
« Reply #14 on: May 27, 2026, 06:29:28 PM »
Offline ridingron
« Reply #15 on: May 27, 2026, 08:09:03 PM »
Wait long enough and you will have to make your own!   :wink:  If you decide to sell it before you get around to fixing it, sell the bracket with it.
Offline guzziart
« Reply #16 on: May 29, 2026, 07:02:53 AM »
I did the Scrambler Cycle alternator conversion years ago, works great.  However, I made the mistake of running the belt too tight and snapped a mounting stud withing the first few months of operation.  Luckily, I was able to extract the broken stud without too much pain, replacements are available from McMaster-Carr, no trouble since.
  At the same time I did the conversion I also replaced the wire harness with one of Greg Benders, he fabricated the harness to accommodate the alternator conversion.
« Last Edit: May 29, 2026, 07:11:24 AM by guzziart »
