Author Topic: Frame A203A?  (Read 1842 times)
Offline motogoro
Frame A203A?
« on: July 02, 2026, 09:01:09 AM »
Just because I'm curious, what does the description "frame A203A" really designate?
I have seen a few LMIV frames on EU eBay listed as "A203A".  AI tells me "A203A" refers to "authentic vintage or replacement chassis".
Who, what, where determined that?  Again, just curious.
Steve M. in SE WI
WMGR 193
MGNOC L-553
Re: Frame A203A?
« Reply #1 on: July 02, 2026, 09:14:53 AM »
Frame replacement, frames are marked. If you buy just a frame in parts as new. There is no model tag, square riveted tag on headstock or bracing.
So, you get a frame with this number stamped on it.  Just a guess, I will bet Joe W knows, or Charlie.
Could be the part number.
Just looked, not PT#, There is #1 & 1A & 1B in parts depending on what is welded on headstock.
Good Luck on answer
« Last Edit: July 02, 2026, 09:27:45 AM by guzzisteve »
Offline Groover
    • Scooteropolis
Re: Frame A203A?
« Reply #2 on: July 02, 2026, 01:03:54 PM »
Found the seller you mention, seems all their listings are followed by numbers similar to that structure; guessing it's their way to locate inventory, like a location on their shelves, etc. Like warehouse location numbers for pickers.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Re: Frame A203A?
« Reply #3 on: July 02, 2026, 01:41:43 PM »
This ^^^. I bought a fender from the same seller that had a similar code.
