Author Topic: search engine  (Read 293 times)
Offline bacongrease
search engine
« on: July 20, 2026, 08:09:38 PM »
 I never could get the search engine to work, wild guzzi site, never, so I gave up.  whats up?   :shocked:
better luck on the googling the WWW  part No.  for Stone dash bulbs.?
« Last Edit: July 20, 2026, 08:18:47 PM by bacongrease »
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: search engine
« Reply #1 on: July 20, 2026, 08:18:35 PM »
You plug in your search keywords, hit return. The search is done by Google and takes you to Google’s search engine. All the listings that you see on Google’s search engine are the search results for the WildGuzzi forum. Easy peasy.
Offline bacongrease
Re: search engine
« Reply #2 on: July 20, 2026, 08:20:00 PM »
yes..thanks.  I was stubborn, I wantedto search wild guzzi..but noooo
Offline Dirk_S
Re: search engine
« Reply #3 on: July 20, 2026, 09:01:59 PM »
But you are searching WildGuzzi. I believe many if not most websites use a 3rd party search engine, Google’s being the most popular. But instead of keeping you inside the forum, you’re taken to Google’s search results webpage. Clicking any and every resulting link provided on the search page takes you to a WG thread. You’re getting the results you want, it’s just taking you outside to handle the detective work before bringing you back in :)
« Last Edit: July 21, 2026, 07:21:06 AM by Dirk_S »
Offline Dr. Enzo Toma
Re: search engine
« Reply #4 on: July 20, 2026, 10:28:59 PM »
If the search box simply doesn't work for you, check for any privacy add-ons in your browsers or settings blocking new windows/tabs from opening.
MGNOC Member
Online TN Mark
Re: search engine
« Reply #5 on: July 21, 2026, 11:41:02 AM »
For me, the Search box is right under the Donate tab on the home page. The Search function works fine on my iPhone, iPad or Laptop.
Re: search engine
« Reply #6 on: July 21, 2026, 03:49:55 PM »
Everything works for me too. Not all technology works with each other on all puters or whatever & I don't care. Buy something that works new or old
Offline Stretch
Re: search engine
« Reply #7 on: July 22, 2026, 08:30:09 AM »
Easier to use Google than to create/code a "local" search engine within the Wild Guzzi site.
It's a little odd at first if you're not used to it, but it works well.  :grin:
                                   -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline ridingron
Re: search engine
« Reply #8 on: July 22, 2026, 07:58:02 PM »
I'm not sure what the problem is. All the links in the search stay on the wildguzzi site which is by design. If you want a larger pool of responses, use a google (or your favorite search engine) search.
« Last Edit: July 23, 2026, 09:11:15 PM by ridingron »
Offline Luap McKeever
  • Owner, WildGuzzi.com
  • Administrator
    • Wildgoose Chase Moto Guzzi
Re: search engine
« Reply #9 on: July 23, 2026, 05:37:35 AM »
Are you getting an error? I'm not seeing any issues. If you're getting an error, a screenshot would be helpful.
For what its worth, the search feature has been a challenge. When using the internal built in search from the forum software and with over 100,000 queries per day, the server just couldn't keep up and was lagging bad. So years ago, I had to implement the Google search option which only returns results from this site. No outside results are displayed at all.
2021 V85TT Centenario E5
2001 California Special
2001 California EV
2007 Honda Goldwing GL1800
