Author Topic: Help- missing key for seat lock (V50) (remove pls)  (Read 2962 times)
Offline boatdetective
« on: May 16, 2015, 12:10:19 PM »
Update-
For those who had any doubt left: I am indeed an idiot.  Of course i found the key- in the fuel tank fill lock.
please remove post an administer 20 lashes.....
« Last Edit: May 16, 2015, 03:31:41 PM by boatdetective »
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
Offline ibis1
Re: Help- missing key for seat lock (V50)
« Reply #1 on: May 16, 2015, 12:18:19 PM »
If you have the key code, a new key could be cut. Otherwise you will need to drill out the lock, unless there is a way of getting to the cable without doing a lot of damage. You should be able to reuse the original cable in the future to remove the seat. :BEER:
2010 California Vintage (Gone)
1971 750 Ambassador (Gone)
2014 California Touring
« Reply #2 on: May 16, 2015, 12:56:03 PM »
can you not just reach up where the pin goes in the spring and release the spring with your finger???  this would work on my v65, not sure if the v50 has a different mechanism.
Online Perazzimx14
« Reply #3 on: May 16, 2015, 01:24:51 PM »
V50 is the same. I pushed the lock wire up and over to the side so it would not engage. Every now and then it would pop back into place and I'd have to reset it.
2017 Road Glide Special
2020 Kawasaki KLX300SM
