Author Topic: Lighting Options?  (Read 3835 times)
Offline willowstreetguzziguy
Lighting Options?
« on: May 15, 2015, 09:23:12 PM »
The headlight brightness and pattern on my "08 1200 Sport is the worst of any cycle I've owned. Low beam is so so and high beam only illuminates the trees! Without spending hundreds and hundreds of dollars on expensive axillary lighting, what options are out there to better light my way on my 1200 Sport?
2008 Guzzi 1200 Sport
Re: Lighting Options?
« Reply #1 on: May 15, 2015, 09:29:25 PM »
Make sure they are properly adjusted and install relays to the beams.
Offline Phil/TX
« Reply #2 on: May 15, 2015, 09:41:24 PM »
I bought Cree led' for $60, and they work great.
Phil
"You will seldom regret what you have done, but you will always regret what you have not"
2024 V7 Stone Corsa (850)
2024 Triumph Speed 400
20 Guzzi V85TT Coast Guard (super chicken)
23 V100 S Mandello ( wing man)
Offline ken farr
« Reply #3 on: May 15, 2015, 10:03:02 PM »
+1 on making sure the beam is properly aimed.
My 06 B1100 ( basically the same machine ) has an incredible light...... ???
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
« Reply #4 on: May 15, 2015, 10:13:14 PM »
How do you like the line of dark shadow right across the point you most need illuminated
« Reply #5 on: May 15, 2015, 10:14:54 PM »
Also, you can't adjust the aim on these headlights up/down..
The shape of the 'ears' is molded into the bucket, it only goes in one position
« Reply #6 on: May 15, 2015, 10:57:23 PM »
Yea! Amazingly bothersome!
« Last Edit: May 15, 2015, 10:58:01 PM by willowstreetguzziguy »
« Reply #7 on: May 15, 2015, 11:01:17 PM »
I can use the knurled knob for adjustment up or down together but not independently, if that's what you mean.
Can I  install a higher wattage bulb?
« Reply #8 on: May 15, 2015, 11:33:49 PM »
Yeah I guess I shouldn't say 'no adjustment' but not enough.
Biggest irritant is that shadow from the break between the H/L bulbs inside the bucket
I'm planning to add driving lights just haven't gotten around to it.
