Author Topic: Murphy strikes again - how to get a Griso seat off?  (Read 5706 times)
Offline not-fishing
« on: May 29, 2015, 12:56:56 PM »
Over the weekend I installed a Back-off flasher.  The flasher works great and people seem to notice it more.
BUT
Everyone I know has a big but -- Pee Wee Herman
When I screwed down the ground to a nearby frame screw that also holds the seat down I must have messed up the seat latch cable.  The key now turns freely for the seat latch.
Does anyone know how to take the seat off when the latch won't release?
I've tried jerking upward and this can't be the first time it's happened to anyone.
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Offline Phang
Re: Murphy strikes again - how to get a Griso seat off?
« Reply #1 on: May 29, 2015, 01:43:34 PM »
you will probably have access to the seat latch if you remove all the three [1], [16], [10] black plastic bits above the rear wheel.
2000 V11 Sport (Green)
1973 V7 Sport (Green)
Offline rboe
« Reply #2 on: May 29, 2015, 01:51:44 PM »
It helps on mine to punch the center of the seat with my knee while pulling up on the back. Seems to work.
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
father guzzi obrian
« Reply #3 on: May 29, 2015, 01:58:34 PM »
Take it to a dealer for an air filter replacement, that should cover it ~;
Offline not-fishing
« Reply #4 on: May 29, 2015, 02:35:25 PM »
The two pieces of plastic 10 & 16 are already gone.
Your suggestion is basically what I figured had to be done -- of course it is the hard way.
Take off the rear rack.
Take off the turn signals - and let them hang.
Take off the rear body wrap around panel.  The #1 black fender panel remaining is captured by the body wrap panel.
Pray to The Lord that there are no bolts under the seat which must be removed to get the body wrap off enough to access the latch.
Griso 1100
Rosso Corsa Lemans
« Reply #5 on: May 29, 2015, 02:52:20 PM »
Have you tried just pushing down on the pillion squab as you turn the keyandnd then lifting it up?
Offline Phang
« Reply #6 on: May 29, 2015, 08:24:31 PM »
ooppss... looks like there are two bolts under the seat  :o
Offline not-fishing
« Reply #7 on: May 30, 2015, 09:51:05 AM »
Last night I skipped the Scotch, put on the Ipod and had at it.
I removed my "cheaper" rack, turn signals & fender eliminator brackets, all the bolts in the rear body shroud and then got to fight those two little under-seat bolts that hold on the rear plastic clamping plate.  the usual tight quarters how the heck do I get a wrench on it battle
Once I got the body panel loose I rotated the front of the panel down and had a good idea -- I reached up and pulled the cable end.
Of course the seat popped of easy and I found my problem.  The lock arm which attaches to the cable had come loose.  That little 2-3 mm screw must have backed out so it's off to the hardware store for the 25 cent part that I will locktite the hell out of when I put it back on.
Being a member of the red suspenders gang I'm also going to rig up a hidden pull to go along with the factory seat lock "belt"
Griso 1100
Rosso Corsa Lemans
Offline Phang
« Reply #8 on: May 30, 2015, 10:15:38 AM »
Well done!
Bill Hagan
« Reply #9 on: May 30, 2015, 01:44:32 PM »
Impressive.
You might, however, done it faster and better with that scotch.   ;D
Bill
