Author Topic: Lario carb problems  (Read 3321 times)
Offline sthomag
Lario carb problems
« on: June 06, 2015, 07:48:37 AM »
I've been working to get my '87 Lario running properly. When I bought it, it had a Rennsport exhaust that looks good and sounds terrific but doesn't seem to do much for its performance. I think its gigantic tubing diameter doesn't match well with the limited breathing ability of the stock engine: the bike quickly runs out of breath and goes flat at higher RPMs, and I note that the stock exhaust has a restriction at the cylinder head.
I have a stock exhaust for it, but the carbs have been rejetted for the Rennsport. I have been able to get stock size main and pilot jets and needles, but the needle jets are proving to be a problem. My Dellortos have the accelerator pumps incorporated into the needle/main jet assembly, with needle like the one at the top of the photo:
http://s655.photobucket.com/user/sthomag/media/Needle-jets.jpg.html?sort=3&o=0
The only replacements I've been able to find are those like the bottom: obviously for carbs without the accelerator pump.
The stock size needle jet is 168. The size the bike came with is 165. Can anybody tell me where I can find an appropriate replacement? Or should I turn down the long needle jet to fit?
By the way, the cam has been replaced with the wider lobes, and it's got a new valve job with Nevada springs.
Re: Lario carb problems
« Reply #1 on: June 06, 2015, 08:39:44 AM »
What carburetors are on your Lario? The accelerator pump setup you describe is the same as that of Dellorto VHBs.
Offline sthomag
« Reply #2 on: June 06, 2015, 08:53:35 AM »
They're PHBH 30s.
« Reply #3 on: June 06, 2015, 12:37:46 PM »
Every diagram of the PHBH 30s I can find doesn't show any accelerator pump at all. That includes the Lario parts diagram on Harper's website.
Offline sthomag
« Reply #4 on: June 06, 2015, 02:04:06 PM »
That's as may be. I've noticed the same thing, and it's part of the problem I have. Nevertheless, they are stamped "PHBH," and they have accelerator pumps.
