So I have a lovely pair of v65tt ( metalic grey 1984 and a white 1988) , both need thrust bearings and probably a crank polish and new shells, bit are getting hard to find for older small block bottom ends. Both gearbox's are getting old and occasionally stick in the lower gears
I was offered a 2013 V7 Stone single throttle body engine and 5 speed box from a damaged v7 with 600miles on the clock by a friend and a plan to fit the complete 2013 engine and box to my grey TT was hatched
I read the 4v conversion thread over at guzzitech with interest and was interested to read that the v7 injector manifolds fit the lario heads as do the v7 exhausts . I cannot see a reason why the v65 carb manifolds and exhausts would not fit the v7 heads?
Having looked a the v7 and v65tt engine/boxes side by side the gearboxes are externally identical (both have the later 12 spline output shafts) and the bottom ends of the engine are identical so should have no problem putting the v7 engine and box in to my tt. To get things running i think i need :-
2013 starter motor
NGK VD05EM spark plug caps
Ducati regulator
Alternator mounted electronic ignition like Electronic Sachse ( unless I can use my existing cam shaft )
Only problem I can no see no solution to is the cam shaft drive rev counter / tacho and cam mounted dyna s my TT has. Ideally I would like to use my v65TT cam shaft and front cover , this would give me the tacho drive and i could use my existing dyna s ignition
