Author Topic: Need to replace LH cylinder head base gasket 2012 Norge  (Read 4546 times)
Offline Lash
  • '20 V85TT Travel '20 Triumph Speed Twin '12 Norge
« on: July 06, 2015, 05:56:09 PM »
I've noticed an oil leak on the left cylinder of my 2012 Norge with 43,500 miles - a pretty good local wrench took a look and diagnosed it as the base gasket.
The wrench is a one man shop, former Ducati mechanic for the local Triumph/BMW/Ducati dealer - 20 years experience, lots of certifications. So I'm confident he can do the job.
Which leads to some questions, as I am by no means a capable mechanic - (Bill Hagan claims I could break an anvil).  :grin:
Anyway -
Any other gaskets, seals, O-rings or other parts that should be replaced at the same time?
- Anything to be careful about during disassembly/reassembly?
- Tips?
- Follow-up tweaks? Re-torque the head after so many miles?
- Special tools?
I know these are basically simple machines, but every marque has their mechanical quirks that aren't in the manuals. Speaking of which, I have the service station manual and spare parts manual. Any other pubs I should have?
Many thanks in advance.
Re: Need to replace LH cylinder head base gasket 2012 Norge
« Reply #1 on: July 06, 2015, 06:21:36 PM »
How much was it leaking?  :gotpics:
Offline Lash
« Reply #2 on: July 06, 2015, 06:29:32 PM »
Not bad really, no oil on the ground, but the entire left side of the engine is a gooey mess. It's sort of a seep. You can see it when it's running.
Most unbecoming for such a fine machine.
« Reply #3 on: July 06, 2015, 06:55:45 PM »
Check both the phase sensor and the oil pressure sender switch before you go pulling it apart.
Getting the barrel off requires dropping the engine.
Offline Lash
« Reply #4 on: July 06, 2015, 09:06:13 PM »
Oh my. Thanks for the input.
Online Wayne Orwig
« Reply #5 on: July 06, 2015, 09:20:35 PM »
As Vasco mentions, there are a lot of things that are more likely to be leaking (and a lot easier to do). I would spend a lot of time with strong lights and mirrors trying to get to the exact cause first.
Offline Lash
« Reply #6 on: July 06, 2015, 10:22:49 PM »
Thanks Wayne, I still need to remove the body work, get the engine clean, then run to see where the leak comes from. It's a real mess right now.
I just put 2,900 miles on her and only had to add 1/2 a quart of oil - keeping it below the full line. Probably a premature diagnosis.
The oil pressure switch was replaced about 4,000 miles ago, but I know they're prone to failure.
Updates as they occur!
Offline Bob Wegman
« Reply #7 on: July 07, 2015, 05:30:48 PM »
Larry, There is a dye made for the purpose of locating difficult to find oil leaks.  You put it in the oil after you clean the engine and after running the engine for a while, you check for the leak using an ultra violet light.  The dye is available at good auto parts stores.
MGNOC # 20848
AMA# 548668
« Reply #8 on: July 07, 2015, 06:30:02 PM »
maybe try keeping the oil half way between the marks.. could it be breather related?
Offline Lash
« Reply #9 on: July 08, 2015, 03:03:08 PM »
I'll check it out thanks!
Offline Stevex
« Reply #10 on: July 09, 2015, 01:58:23 PM »
If it is the base gasket, have you thought about re torque-ing the head down first?
« Reply #11 on: July 09, 2015, 03:34:27 PM »
Won't work. Both head and base gaskets are steel composites and incompressible.
Offline Stevex
« Reply #12 on: July 09, 2015, 03:49:06 PM »
Things have moved on since my LM2 then    :laugh:
