Author Topic: EV motor in loopframe issues  (Read 3668 times)
Offline ratguzzi
    • road kill
« on: August 04, 2015, 10:45:37 AM »
I started this project a while back. I had my 98EV motor mounted in with some cool brackets and thought the alternator cover would clear with just a slight fender mod.
I was surprised how tight it was until I realized that I had a 67 frame with the tighter rake.
Soooooo, I bought the adapter from Mark at Guzzi classics, got a loop timing chest cover machined to clear the timing chain, pulled the motor out of the frame, drilled and tapped for the studs for the new alternator conversion kit for loopframes and then....
I pulled the timing chest cover and realized Mark's adapter just isn't going to work on the later crankshaft. And I have no desire to swap out the crankshaft.
I gave away my other loop frames so now I guess I need to find a later loopframe to work with.
Always something.......... ..
JB
John Boettcher
Wonder Lake, IL
"I'll quit riding when they pry the handgrips out of my cold dead fingers"
Offline Scott DeRoss
Re: EV motor in loopframe issues
« Reply #1 on: August 04, 2015, 10:54:34 AM »
Give The Guzzi Doctor Joe Walano a call he might have what you need. He is near you in North Chicago  Scott
« Last Edit: August 04, 2015, 10:56:21 AM by Scott DeRoss »
2007 Vintage (Vinnie)
2017 V9 Roamer (Sunny)
1-76 & 3-78 Robins
1975 Honda CT90
1979 Beneli G2 moped
75 850t wifes (Plum Crazy)
79 Honda Ct70 (restored)
MGNOC L-661
Never take life so serious you won't get out of it alive
Offline ratguzzi
    • road kill
« Reply #2 on: August 04, 2015, 10:59:25 AM »
Yeah, know Joe well. He has a couple of project bikes that would work but I don't need a drive line.
JB
John Boettcher
Wonder Lake, IL
« Reply #3 on: August 04, 2015, 11:01:14 AM »
When I was out there last spring, Mark had *several* loop frames.
« Reply #4 on: August 04, 2015, 11:05:35 AM »
JB
The rake of the V700 and other Loop frames is the same, the only difference is an approx. 1" longer frame length on Ambo and Eldos and triples that have 20 mm less offset.
http://www.thisoldtractor.com/moto_guzzi_loopframe_frame_differences.html
I still have a spare frame or two in the attic.
Offline ccoli
  • What? Me Worry?
« Reply #5 on: August 04, 2015, 11:24:45 AM »
Got an early Ambo frame you can have. No title.
Wisconsin MGNOC Rep
Offline Shorty
« Reply #6 on: August 04, 2015, 12:25:46 PM »
Loop frame, powder coat or plain: Oklahoma:  http://oklahomacity.craigslist.org/mcy/5129172059.html
« Last Edit: August 04, 2015, 12:28:41 PM by Shorty »
Offline ratguzzi
    • road kill
« Reply #7 on: August 04, 2015, 01:52:05 PM »
Just picked up a 1971 frame from Rose Farm. Thanks for all of the offers and help!
JB
John Boettcher
Wonder Lake, IL
Offline Karl Von
    • Classic Old Motorcycle Association
« Reply #8 on: August 05, 2015, 04:08:08 PM »
The adapters only work with the tapered bosch alternator cranks.  My father is going through the same issue in putting a strada motor in a eldo.  They cut the front of the crank and are having a custom puppy adapter made
