As I mentioned in your other post, I had trouble with the top of my right shock. The bolt came right out, but I had to use a gear puller to get the shock off the post. There was some substance that I can only assume was a Loctite material on there. I sanded it off before I put the new shock on.
Maybe you live too close to the ocean?
Nope, easy peasy on mine.Maybe you live too close to the ocean?
Got it off with heat and a puller. It was coated in a rough black material, probably paint.This is a pivot point - why wasn't it polished and lubricated? Not only did Guzzi install rather poor shocks, they also made them almost impossible to remove.
