Author Topic: 2007 griso blank dash ????  (Read 3462 times)
Offline dsrdave
« on: July 07, 2016, 11:09:02 AM »
I bought this bike recently, it had some minor front end damage.  I got everything taken care of and started riding.  The only problem was I had to input the 5 digit 00000 code every time I wanted to start the bike (pita).  I took it to an old reliable dealer and he installed a new ignition switch/antenna assy and a new dash.  Now the bike starts and runs great without inputing codes.  But, the dash is blank, no headlamp and no turn signals.  The needle used to sweep and warning lights come on when the key switch was operated and now NOTHING  he has given up and this is WAY above my pay grade.  I don't know much history of the bike but things worked well before and not now.  Any ideas or help is MUCH appreciated.  Thx, Dave.
Re: 2007 griso blank dash ????
« Reply #1 on: July 07, 2016, 12:07:53 PM »
The indicators are controlled by the dashboard, not entirely sure about the headlight but the fact that it is related to whether the engine is running would make me think that it is using the phase sensor signal via the dash, the fact that the LCD screen is not operations also points to a faulty dash.
Try unplugging it and thoroughly cleaning the pins and plug. After that it's time to grab a multimeter and start back probing the loom but it sounds like a dud dashboard.
Offline Darren Williams
  • Finally got me a Griso!
« Reply #2 on: July 07, 2016, 12:27:53 PM »
"I took it to an old reliable dealer and he installed a new ignition switch/antenna assy and a new dash."
If you still have the old dash, you might try it again to see if results are different.
Offline dsrdave
« Reply #3 on: July 07, 2016, 12:55:12 PM »
I tried the old dash and same results.  Where does the power/signal for the dash come from ???  Is it the ECU or from a 12v supply in the harness.  The dealer thought someone had altered the ECU previously.
« Reply #4 on: July 07, 2016, 03:00:11 PM »
It looks to me as though the dash gets 12V from inputs 11, 21 & 31 from the ignition switch
Check also the ground on pin 16 it may be loose where it's attached to the chassis.
http://www.thisoldtractor.com/guzzi007/schematics/2006_Griso_1100.gif
I'd be surprised if the wire on pin 16 doesn't go back to the battery
Does anyone have the Dash and ECU pinout?
« Last Edit: July 07, 2016, 03:06:02 PM by Kiwi_Roy »
Moto
« Reply #5 on: July 07, 2016, 04:05:57 PM »
Dashboard pinouts from pp. 7-4 to 7-5 of the Griso 1100 Workshop Manual:
The pinout of the grey connector is as follows:
Pin   Service
1      + KEY
2      RIGHT INDICATOR CONTROL
3      HIGH BEAM INPUT
4      -
5      -
6      K-LINE
7      -
8      SELECT 1 - SET
9      FUEL LEVEL SENSOR
10      AIR TEMPERATURE SENSOR
11      + BATTERY
12      LEFT INDICATOR CONTROL
13      -
14      -
15      -
16      GENERAL EARTH
17      OIL PRESSURE SENSOR INPUT
18      SENSOR EARTH
19      GENERAL EARTH (OPTIONAL)
20      GENERAL EARTH (OPTIONAL)
The pinout of the black connector is as follows:
Pin     Service
21      + BATTERY
22      FRONT LH INDICATOR CONTROL
23      REAR LH INDICATOR CONTROL
24      ANTENNA 1
25      -
26      CAN H
27      -
28      LIGHTS RELAY CONTROL
29      -
30      SELECT 2
31      + BATTERY
32      FRONT RH INDICATOR CONTROL
33      REAR RH INDICATOR CONTROL
34      ANTENNA 2
35      -
36      CAN L
37      -
38      -
39      -
40      SELECT 3
ECU Pinouts (pp. 7-8 to 7-9 of Workshop Manual):
Black connector pinout (engine)
Pin    Service
1      Not used
2      Not used
3      TPS signal
4      Not used
5      Engine temperature signal
6      Not used
7      Not used
8      Not used
9      Stepper motor (+)
10      Right cylinder coil control
11      Not used
12      Not used
13      Not used
14      Air temperature signal
15      Not used
16      Not used
17      Stepper motor (+)
18      Stepper motor (-)
19      Stepper motor (-)
20      Power supply 5V (NTC sensors)
21      Not used
22      Not used
23      Neutral sensor signal
24      Not used
25      Engine speed sensor signal
26      Not used
27      Not used
28      Left cylinder injector control
29      TPS power supply
30      Not used
31      Not used
32      TPS negative
33      Not used
34      Rpm sensor wave trap
35      Engine speed sensor signal
36      Not used
37      Right cylinder injector control
38      Left cylinder coil control
Grey connector pinout (chassis)
Pin   Service
1      Starter relay control pin 85
2      Not used
3      Not used
4      Protected power supply from instrument panel
5      Not used
6      Secondary relay control pin 86
7      Immobilizer line
8      Starter relay control pin 85
9      Not used
10      Not used
11      Oxygen sensor negative control
12      Not used
13      Not used
14      Not used
15      Not used
16      K line (diagnosis)
17      Power supply from main relay
I agree this seems like a dash failure, because of the combination of symptoms.
Moto
« Last Edit: July 07, 2016, 04:07:44 PM by Moto »
« Reply #6 on: July 07, 2016, 06:11:49 PM »
"installed a new ignition switch/antenna assy and a new dash." and "I tried the old dash and same results."
Since the old dash used to work OK and now doesn't, to me that points to the new ignition switch, and/or connectors surrounding it, not feeding the ECU, err dash, properly with power.
« Last Edit: July 07, 2016, 06:45:28 PM by Darren Williams »
« Reply #7 on: July 07, 2016, 06:35:19 PM »
Thanks Moto, that's a great help.
I was wrong pins 11, 21 & 31 should have power all the time, it's pin 1 that comes on with the key.
I suspect pin 1 will have 12 Volts since the bike runs the wire going to 1 also goes to the injection relay.
Measure for Voltage on pin 16, there should be none since it's supposed to be ground that is the Negative for dash
I think you could also stuff a grounded wire in either 19 or 20
To reiterate, + 12 on Pin 1, -12 on Pin 16, 19 or 20
I realize it's hard to probe the small connector.
Unplug the dash and stuff 2 wires connected to a bulb in 1 and 16 of the socket, the lamp should light up, if it doesn't you have no power, pull the wire out of 16 and touch it on ground if it still doesn't light you have no power on 1 from the ignition switch.
« Last Edit: July 07, 2016, 07:01:58 PM by Kiwi_Roy »
Moto
« Reply #8 on: July 07, 2016, 06:38:02 PM »
Since the old dash used to work OK and now doesn't, to me that points to the new ignition switch, and/or connectors surrounding it, not feeding the ECU properly with power.
Oops. Missed that. Duh.
Offline dsrdave
« Reply #9 on: July 07, 2016, 07:12:59 PM »
Great, lots of good info.  I have a number of things to try.  This is the reason I like working on the older SIMPLER bikes.  It's just that the newer bikes are great fun when running right.
Offline dsrdave
« Reply #10 on: July 08, 2016, 07:33:57 AM »
Checking things today at the dash connector,  pin #1,11,21,31  all have 12v power  and pin #16 is providing a good ground...........  I'm leaning toward a bad dash ?????  Any other ideas ???
Moto
« Reply #11 on: July 08, 2016, 09:35:35 PM »
Previously, you said, "I tried the old dash and same results." Could you clarify, please, exactly what the other dash does? Does it have exactly the same symptoms you reported for the new dash? Namely:
"the bike starts and runs great without inputing codes.  But, the dash is blank, no headlamp and no turn signals.  The needle used to sweep and warning lights come on when the key switch was operated and now NOTHING..."
If you get exactly the same results with both dashes, it isn't likely to be a dash problem (especially since I've never heard of exactly this set of symptoms before).
If there are any differences in symptoms between the two dashes, that could be helpful to know too. Best bet would be a systematic layout of symptoms for the two dashes, for example in a table.
« Reply #12 on: July 08, 2016, 10:59:33 PM »
Do you know anyone else with a Griso, perhaps you could try your dash out on another bike.
It's hard to imagine why the dash should quit,
Is it possible to measure the Voltage on the connector while it's plugged in?
I'm wondering if there's a fault dependent on the cable angle.
« Last Edit: July 08, 2016, 11:06:48 PM by Kiwi_Roy »
