Author Topic: V65 new steering lock fitting - I'm lost...  (Read 1987 times)
Offline chrisk
« on: January 25, 2016, 12:18:38 PM »
Hi, I bought this new from gutsibits but cant work out how to fit it..?
When I fitted one to an RD Yamaha the key would go in and then the whole mechanism/shaft would slide forwards into the steering tube, therefore locking the steering. This one just twists and I can't get the shaft to slide forward. I've removed the two grub screws one by one but it makes no difference.
Does this seem right... any ideas ?
Offline Groover
    • Scooteropolis
Re: V65 new steering lock fitting - I'm lost...
« Reply #1 on: January 25, 2016, 12:38:09 PM »
I think you have to turn the barrel a little to the left, then push the assembly in when the pin and the woodroof looking shoulder line up, then turn the key again. You should also have a spring in front of all that I think.
I'm terrible at explaining this, but I've put in a few of those locks. The older vespas have that same system.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline Groover
    • Scooteropolis
« Reply #2 on: January 25, 2016, 12:40:42 PM »
Also, make sure the steering isn't too far turned. I've noticed on my guzzi that it has to be "almost" all the way turned, but if I rely on the lower triple-tree stoppers to be where it needs to be, it won't lock. I'd say move the steering a little left and right and see if you find the hole in the steering tube that way,
« Last Edit: January 25, 2016, 12:41:43 PM by Groover »
1980 Vespa SI Moped
Offline v65tt
    • Streffords
« Reply #3 on: January 25, 2016, 01:55:19 PM »
im sure there are 2 different types of steering lock
Iain
1986 V65TT
2016 SWM SILVER VASE 440
1974 HONDA XL250 MOTOSPORT
http://www.streffords.net
