Author Topic: Clutch noise differences - Norge vs Griso  (Read 3037 times)
Offline PJPR01
« on: February 16, 2016, 01:39:16 PM »
Folks...
I've been riding the 2015 Griso a bit more to get some miles on it, and I notice that when I pull in the clutch to engage 1st gear, there is virtually NO noise at all.  When I compare that to my 2008 Norge, I have always heard since new a bit of raspiness, and although it's not getting worse, it makes me wonder why the difference.
I presume both are dry clutches...is there a significant design improvement in the newer Guzzi vs old or is there some other explanation?
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline Groover
    • Scooteropolis
Re: Clutch noise differences - Norge vs Griso
« Reply #1 on: February 16, 2016, 01:46:28 PM »
Could it be that the Norge clutch needs adjusted a tiny bit to clear the clutch catching when pulled?
If I'm, completely off, it's because I know nothing about those two bikes  :grin:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline Bisbonian
  • Living the Dream
« Reply #2 on: February 16, 2016, 01:57:57 PM »
I assume that your 2008 Norge, like my 2008 1200 Sport, has the dual disc clutch. This jingles with the lever pulled in.
Did they change the clutch on the 8v engines that you would have in your Griso?
I'd expect the answer is in the newer clutch design.
Offline PJPR01
« Reply #3 on: February 16, 2016, 04:57:24 PM »
Thanks both for the speedy replies, it could be both!
I have to study the schematic a bit, and check with Mike/Larry at MPH when I take the Norge in for the regular service here shortly.  All works perfectly, just that little noise delta.  Fun now as well to note that the Griso is starting to pop a little on decel as well...which is also more reminiscent of the Norge...but it's noticeably more "buzzy" thru the handlebars than the Norge...just needs a quick 10,000 miles on it to get smoother I should imagine!
Paul R
2008 Silver Norge
2002 V11 Scura
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #4 on: February 16, 2016, 04:57:46 PM »
The single plate clutches go quiet with the clutch lever pulled in, opposite to the twin plate versions.
Has the 2015 Griso gone single plate?
Offline Trogladyte
  • Location: South London - home of the world's best football team.
« Reply #5 on: February 16, 2016, 05:08:01 PM »
Different clutches I think. Don't know, but suspect the Norge has a dual plate clutch, so it will jangle a bit when disengaged. The Griso has a single plate clutch that  doesn't jingle - well , mine does, anyway.
Offline PJPR01
« Reply #6 on: February 16, 2016, 06:35:35 PM »
Then I believe you have hit on the source of the difference there...sounds logical!
Paul R
2008 Silver Norge
2002 V11 Scura
