Author Topic: V7R headlight won't work...  (Read 1781 times)
Mrkitty2
« on: February 17, 2016, 07:50:19 AM »
Hi all. Headlight on '13 V7R isn't working. It WILL work on the pass button (high beam) with engine off or running,  but won't light up as normal when engine running on high or low beam. Everything else electrical is working fine. I've opened up the left hand switch and cleaned it up, checked all fuses. How does the bike turn on the headlight once the engine is turning? ECU? Or sensor somewhere? All help gratefully received.
Offline sign216
Re: V7R headlight won't work...
« Reply #1 on: February 17, 2016, 07:57:31 AM »
MrKitty,
Look at the wire diagram and trace it back to a likely switch or joint.  Sorry, I can't think of a a quicker answer.
The wire diagrams are available online, from a variety of sources.  I can send you one later on today.
Joe
« Last Edit: February 17, 2016, 08:34:31 AM by sign216 »
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
Mrkitty2
« Reply #2 on: February 17, 2016, 08:05:05 AM »
Thanks Joe!
Offline guzzi4me
« Reply #3 on: February 17, 2016, 09:31:20 AM »
Burned out low beam element?
Replace the bulb. If problem fixed great.
If not you have a spare bulb for later.
Ride safe and often....
Jeff
Jeff S
Fruita CO
01 Jackal "Mistress"...sold
Mrkitty2
« Reply #4 on: February 17, 2016, 12:09:17 PM »
Thanks Jeff, I've tried a different bulb, no joy.
So after a bit more poking around I find three relays to the right on the frame under the tank...
First has 2 pale brown wires, 1 white and green, 1 yellow and purple.
Second has 1 red and brown, 1 blue and white, 1 red and green, 1 red and white.
Third has 2 red and green, 1 blue and yellow and 1 purple.
I've ordered a new relay (all three are the same 30A 4 pin) so I can swap them out to check, but does anyone know whether any of these, and which one, control the headlight circuit after startup?
Offline not-fishing
« Reply #5 on: February 17, 2016, 12:16:24 PM »
I went through the same headlight problem with my Griso a year or so ago.  I swapped relays because the Griso's are all the same also.  Funny thing is after swapping the relays everything worked.  I swapped back and they still work.  I attribute the relay working to the fact that I have a spare under the seat...just in case.
I'm going through much the same problem with my G11 oil pressure sending unit. It's the bad electrical connection to the unit that's the problem.  I figure the next time I pull the fuel tank I'm going to "belt and red suspenders" the electrical connection.
Just another day in the life of Italian Electrics.
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Mrkitty2
« Reply #6 on: February 17, 2016, 12:38:22 PM »
Found this which appears to identify the relays:
http://wildguzzi.com/forum/index.php?topic=78113.0
Mrkitty2
« Reply #7 on: February 19, 2016, 07:02:54 AM »
Sorted! A dead relay, one of the three, on my bike the one nearest the rear, 2 brown, 1 white/green, 1 yellow/purple. That's the relay that controls the headlight dipped and main beam with engine running.
« Reply #8 on: February 19, 2016, 03:46:37 PM »
Excellent work!
Let us give him a high five!
« Last Edit: February 19, 2016, 03:47:54 PM by Penderic »
