Author Topic: Refitting stock air cleaner/breather box on '79 1000SP  (Read 2771 times)
Offline ukdavo
« on: April 01, 2016, 01:18:49 PM »
This thing is driving me crazy. Decided to change air cleaner, wanted to clean/adj distrib anyway. A bit of a struggle to pull the boot off and back the breather box out. Checked the pcv valve; it has been updated & looks clean. BUT - reassembling this thing is freaking HARD. Velocity stacks in the way, engaging the boot with the lip on the breather box is impossible, but it won't fit if I preassemble it. I MUST be doing something wrong - any ideas? I searched the archives, no luck. Are the velocity stacks necessary? Sure would appreciate some advice. Thanks in advance. David
Re: Refitting stock air cleaner/breather box on '79 1000SP
« Reply #1 on: April 01, 2016, 01:54:03 PM »
If you can get to the part of the rubber that won't attach to the carb, take a small flat screw driver and put it between the rubber and metal.  Move it along and this will spread the rubber so the 2 will attach.
Offline mtiberio
    • TiberioRacing
« Reply #2 on: April 01, 2016, 02:02:06 PM »
did you pull one of the carb/manifold assemblies? 3 bolts. only way to do it without losing your mind that I know of short of crabbing the frame.
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #3 on: April 01, 2016, 03:50:02 PM »
Some of those early breather boxes were designed by the Marquis de Sade.
Offline yackee
« Reply #4 on: April 01, 2016, 05:38:13 PM »
Easy to switch to pod filters!
« Reply #5 on: April 01, 2016, 08:35:55 PM »
That's why I changed to pods.
Offline ukdavo
« Reply #6 on: April 02, 2016, 01:31:36 AM »
Thanks, folks. I'll try pulling one of the carbs. I try to keep things stock if I can; next time I may buy a newer breather box and switch to a K&N setup. Crazy design for a routinew maintenance item!!! Davbid
« Reply #7 on: April 02, 2016, 04:04:43 PM »
Just keep the stock items for resale with the bike when/if you sell.
« Reply #8 on: April 02, 2016, 04:17:16 PM »
Maybe ol' Lino Tonti was a descendant of the Marquis de Sade?  :wink:
