Author Topic: california II / california III engine / transmission question.  (Read 1373 times)
Offline arveno
    • ddleathers.com
Hi All
I was wondering are the california II and a california III sharing the same engine/transmission/rear drive/gearing ?
They look the same,same size 88x78mm ( 948 cc. ) and 5 speed trans .
Any important difference/improvement ?
Or basically same thing ?
( except those few caliIII bikes that came with big valve motors )
just a curiosity .
thanks
Offline TOMB
Re: california II / california III engine / transmission question.
« Reply #1 on: April 17, 2016, 04:52:16 PM »
Others may chime in so here goes.
The Call11 is the smoother engine of the two . In the Call 111 the factory changed the Wrist pins so the Cali 111 has heaver wrist pins (they didn,t seem to rebalance the rotating mass) so there is a slight buzz/vibration in the Cali 111 engine, from my experience and first hand input from actual owners.
Other than that both are good bikes and the other changes  are cosmetic ,carbs ,valve size etc.
Others will be along shortly and add additional comments.
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
