Author Topic: PLASTIC ON HEADER PIPE  (Read 3968 times)
Offline Spuddy
« on: May 18, 2016, 01:33:21 PM »
Moving Lola (still warm) around in the garage, I sorta dropped her on one of those plastic detergent buckets. While I got most of the plastic off the warm header pipe, a black splotch remains.  Although I can live with it, I wonder if there are any other cleaning I haven't thought of.
Spud
'13 Stelvio NTX
'07 California Vintage
'01 W650
Offline normzone
Re: PLASTIC ON HEADER PIPE
« Reply #1 on: May 18, 2016, 01:41:51 PM »
The bike is ruined. Post a picture of Lola and we'll figure out someway to get it out to me so you don't have to see it any more.
Although if you ran the bike warm and wiped at it with first wood, then stainless steel scrubber, you'd probably get most of it.
Run it to hot, and you'll bake it on, so caution is advised. This is a wholly uneducated opinion, coming from a guy who hopes you'll give him the bike.
« Last Edit: May 18, 2016, 02:08:34 PM by normzone »
redrider
« Reply #2 on: May 18, 2016, 01:46:02 PM »
Easy Off oven cleaner but be careful with the overspray. Apply on cold metal before bedtime and rinse off the next morning. Follow with Nevrdull. This might also be a time for the battery charger/sulphuric acid treatment.
« Reply #3 on: May 18, 2016, 02:08:55 PM »
I have found the best solution is to ride it.
A. You can't see it from on the seat. :evil"
B. With time the heat will turn it to carbon and it will brush off easily.
Online StuCorpe
« Reply #5 on: May 18, 2016, 03:36:55 PM »
Most of the time chrome cleaner works real well. Used it several times.
Offline Air-Cooled
« Reply #6 on: May 18, 2016, 03:45:20 PM »
Warm it up then scrape it with the edge of a penny. The penny will not scratch steel, but does a nice job of removing baked on plastic.
1973 Moto Guzzi V7 Sport, 2016 Moto Guzzi Stornello, 2023 Vespa Primavera
Online pehayes
« Reply #7 on: May 18, 2016, 03:48:51 PM »
Easy Off, then a PLASTIC scraper, then wadded up aluminum foil.
Rinse and repeat.
Offline normzone
« Reply #8 on: May 18, 2016, 04:43:29 PM »
Hey, I still think we should at least get a picture, even if you guys are discouraging him from giving up on it and giving it to me.
Offline jetmechmarty
« Reply #9 on: May 18, 2016, 04:51:01 PM »
The simple way to remove it, without scratching the pipe or actually having to work, is to soak a rag with MEK (methyl ethyl keytone) and lay it on the spot.  After a moment, it should wipe right off.  Do it outside and wear gloves to avoid getting that solvent on your skin.
Marty (in Mississippi)
No Guzzi right now
Offline Linerpilot1
« Reply #10 on: May 18, 2016, 09:15:29 PM »
Don't know if this will work on the plastic,but I've removed burnt on bootsole from my exhaust a few times by getting the pipe good and hot, then giving it a shot of EasyOff. Usually dissolves and run right off. But be careful and DO NOT breathe the cloud of fumes it creates.
2004 California EV Touring
2004 V11 Lemans Nero Corsa
2006 Yamaha Stratoliner S
2016 Eldorado
AeroGriso
« Reply #11 on: May 18, 2016, 11:37:34 PM »
I once owned a R100RT, and while riding through town a plastic grocery bag blew onto my header pipe.  I didn't know what to remove it with, so I left it alone.  It crusted up pretty solid.  I had it in for maintenance (local dealer at that time was Fort Worth BMW owned by Perry Bushong), and Perry suggested using crome cleaner and a copper scouring pad (for pots & pans).  It worked fine, as the copper is less hard than the stainless steel pipe.  I felt kind of stupid that I hadn't thought of that myself, since I'm an aircraft structural analysis engineer.
« Reply #12 on: May 19, 2016, 05:28:39 AM »
Burnt some plastic on to the Breva's exhaust. Couldn't find my metal cleaner but as we had a ride or two lined up, well, I rode.
Burnt plastic has completely gone. :thumb: About 5-600 miles of riding at an "exuberant" pace should do the trick. Trust me, I are a doctor. :rolleyes:
Offline Spuddy
« Reply #13 on: May 19, 2016, 12:11:35 PM »
Thanks gentlemen!  I'm gunna do all the prescribed fixes all at once!
And Norm, I'll enclose some pictures later...
Spud
'13 Stelvio NTX
'01 W650
« Reply #14 on: May 19, 2016, 12:45:09 PM »
 Ahh , Perry Bushong , there is a character  :laugh: All around good guy .
Spud
 OK Spuds , we are gonna need video of that  :laugh:
Offline Toecutter
« Reply #15 on: May 19, 2016, 12:52:11 PM »
Easy off.
Ride it til it's hot, shut it down, spray with Easy-off oven cleaner (cover everything to protect from overspray!!!)
Offline pressureangle
« Reply #16 on: May 19, 2016, 02:23:37 PM »
Try this. If not, try 3M adhesive remover. Don't use any scouring pads, or cleansers. You have to remove it chemically or it will ruin the finish.
https://www.barkeepersfriend.com/cleaning-products/cleanser-polish/
Offline hudson
« Reply #17 on: May 24, 2016, 07:47:56 AM »
as mentioned above - Get pipes hot, easy off oven cleaner and if SS piples, use a stainless steel scrub pad.  I also sprayed easy off on and left overnight.  Came right off.
75 850T
71 R75/5
Offline Dilliw
« Reply #18 on: May 24, 2016, 08:22:17 PM »
O.k. so I had the exact same problem.  Heard the rain coming so I rushed out to throw the cover on.  Unfortunately the Griso pipes were still hot.
It looked like this:
So I went to Walmart and got these:
And 5 min later it looked like this:
Pretty straight forward.  Heat the pipe, wipe a little of that iron cleaner with a cotton (not micro) towel, and a little bit of scrub with the copper wool.  It's a little duller in the second picture as I followed up with some all metal.
George Westbury
Austin, TX
