Author Topic: Guzzi question  (Read 3418 times)
Guzzi question
« on: June 06, 2016, 12:14:44 PM »
Can anyone tell me what the diameter of the front fork on a 83 LeMans III is?
Re: Guzzi question
« Reply #1 on: June 06, 2016, 12:22:57 PM »
 Aren't they 42 MM ?
Re: Guzzi question
« Reply #2 on: June 06, 2016, 12:25:07 PM »
Diameter of the original fork tubes is 35 mm.
« Last Edit: June 06, 2016, 12:25:37 PM by Antietam Classic Cycle »
Re: Guzzi question
« Reply #3 on: June 06, 2016, 12:29:06 PM »
That's not fair!  I asked about /2 front fork tube diameter almost an hour ago, and you answered him before me!  Wait your turn, John!  :boxing:
Re: Guzzi question
« Reply #4 on: June 06, 2016, 12:30:02 PM »
RATS! I'm looking for some headlight brackets and the ones I really like are 51mm. they have a holes for turn signals, any ideas Charlie?
Re: Guzzi question
« Reply #5 on: June 06, 2016, 12:31:17 PM »
You must have been asking in Alaskan : ) SPEAK ENGLISH!!!
Re: Guzzi question
« Reply #6 on: June 06, 2016, 12:39:27 PM »
 Must be designed for shrouded forks , don't think there are many tubes that large . Or maybe USD forks , dunno .
Re: Guzzi question
« Reply #7 on: June 06, 2016, 12:48:00 PM »
Found this. they have different sized clamps including 35mm
http://www.speedmotoco.com/Hinged-Shorty-Headlight-Bracket-sttreetfighter-p/hsb3358.htm
Offline Curtis Harper
    • Harpers Moto Guzzi
Re: Guzzi question
« Reply #8 on: June 06, 2016, 12:49:48 PM »
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
Re: Guzzi question
« Reply #9 on: June 06, 2016, 12:53:01 PM »
/2 has Earles type forks... Do you mean an R60US? ;-)
Re: Guzzi question
« Reply #10 on: June 06, 2016, 12:55:42 PM »
 No , he was asking about the diameter of the trailing link upper section on a /2 Earles fork .
Re: Guzzi question
« Reply #11 on: June 06, 2016, 12:58:32 PM »
I bought a set of these for my Morini, but ended up straightening the originals. If anyone wants to buy them, let me know.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=37_154&products_id=4670
Re: Guzzi question
« Reply #12 on: June 06, 2016, 01:02:52 PM »
Well, that's kind of a trick(y) question for several reasons. 1) /2 forks are made with oval section tubing/castings and 2) they're welded to what would be a lower triple clamp on other bikes.
Re: Guzzi question
« Reply #13 on: June 06, 2016, 01:05:11 PM »
 Yeah , but didn't want to get off into all of that . The question came up on a recent thread about a custom /2 beemer .
Re: Guzzi question
« Reply #14 on: June 06, 2016, 01:15:23 PM »
As it turns out the trail angle of the /2 forks doesn't work with the tonti frame.  So the question is moot.  Thanks for jumping in on it though.  I had no idea about how they were made.  It was fun.  My leading link quest continues.
If the forks are 35mm and the headlight mounts are 51mm why can't you get sleeves made with the od/id you need and a setscrew to hold them?  Or make the sleeves take all the space between the trees and then you wouldn't need a setscrew.
