Author Topic: Arg! Norge leaking again.  (Read 1129 times)
Offline Gliderjohn
« on: August 22, 2016, 08:55:07 AM »
Last time it was the oil lines. This time at this point all I can see is oil along lower left side of engine. Everything from the bottom of the jugs on up appears dry. Dipstick door is oil moist on the inside. Lower left side of chin fairing is moist. After about a 70 mile ride yesterday it left about a six inch across puddle on the floor. The oil light is coming on again intermittently at idle sometimes. It did that when I had the oil line leaks. Oil level is still fine.
Frustrating.
East Mountains, NM
Offline MGrego
Re: Arg! Norge leaking again.
« Reply #1 on: August 22, 2016, 10:46:12 AM »
Bad Luck !
The phase sensor and oil pressure switch would be possibilities.
Let us know what you find out --
Offline Piglet
« Reply #2 on: August 22, 2016, 11:43:00 AM »
FWIW I had to replace an oil pressure sensor because it was coming apart.  This was on my roundhead
