Author Topic: Griso rear shock spring  (Read 1526 times)
omega1
« on: August 26, 2016, 02:15:40 AM »
My new to me 2013 Griso feels undersprung at the rear. Clearly a Matris R shock is the ideal answer but it is rather expensive.
Has anyone replaced the spring on the standard shock with good results and if so what did you use?
TIA
Offline Thirtyaughtsix
Re: Griso rear shock spring
« Reply #1 on: August 26, 2016, 03:05:49 AM »
Dave Hagon maybe?
2019 V7 III Stone " Murci "
1975 850T " Guzziaughtsix "
Offline not-fishing
« Reply #2 on: August 26, 2016, 03:32:32 AM »
I would also like to know.  My understanding is you have to buy a new shock with the spring because for us of larger girth you can't get a spring that's heavy enough that fit's the stock shock.   it's the old belt is to tight and there's no notches left problem that some of us know all to well
Mark
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Offline tris
« Reply #3 on: August 26, 2016, 04:48:57 AM »
Nitron do one for the Norge 12 so maybe could sort you out?
http://www.nitron.co.uk/catalogue_main.php?catID=13024
1993 TW125 "POS" - Resting
