Author Topic: Just to clarify  (Read 3614 times)
Offline hannibal smith
Just to clarify
« on: September 27, 2016, 10:36:00 AM »
2007 V7 Classic
10-60 for the engine-
85-90 for the gearbox (what I would call the transmission)
85-140 for the transmission (what I would call the final drive)
Just to clarify!
Offline twhitaker
Re: Just to clarify
« Reply #1 on: September 27, 2016, 11:51:18 AM »
Sounds right. If you get the quantities right, you are golden.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Re: Just to clarify
« Reply #2 on: September 27, 2016, 11:58:14 AM »
Thanks- Just confused a bit in the OM about terminology- I assumed the "heavier" fluid would go in the final-
Offline twhitaker
Re: Just to clarify
« Reply #3 on: September 27, 2016, 12:00:30 PM »
It's been known to happen, putting 250cc lube in the 'gearbox' and having 5th go bye bye.
MGNOC-11168
Dayton, OH
Re: Just to clarify
« Reply #4 on: September 27, 2016, 12:02:43 PM »
2007 V7 Classic
Just to clarify!
From the V7 Classic factory manual:
Engine Oil - 1780cc / 108.62cu in
Gearbox Oil (i.e. Transmission) - 1L / 0.26US Gal
Transmission (i.e. Rear) - 170cc / 10.37cu in.
& under Recommended Products
AGIP RACING 4T 10W-60 - Engine Oil
AGIP GEAR MG/S 85W-90 - Gearbox Oil (i.e. Transmission)
AGIP GEAR MG 85W-140 - Transmission Oil (i.e. Rear)
Re: Just to clarify
« Reply #5 on: September 27, 2016, 12:06:36 PM »
Thanks all!
Kinda figured, but Italians are known to do their own thing!
Offline ITSec
Re: Just to clarify
« Reply #6 on: September 27, 2016, 12:31:27 PM »
And just to further clarify...
Many gear oils will carry both the MG and the MG/S certifications. As I recall, one is specific to straight gears and the other to hypoids, but it is quite possible to make lubricants that meet both requirements. For big blocks, oils such as Mobil1's 75w90 are suitable for both gear types and can be used in both sections of the drive (other brands may also be suitable).
Bikes that use more widely separated grades, like the small blocks of course, need two different weights - but you may find oils, especially synthetics, that carry both MG and MG/S or equivalent specifications.
ITSecurity
2013 Stelvio NTX - Copper
2008 Norge GT - Silver
I am but mad north-northwest!
Re: Just to clarify
« Reply #7 on: September 27, 2016, 07:57:49 PM »
Ok- refilled engine oil to 1.8L of Motorex 4T 10/60
Fired her up for a few minutes, shut her off, and started checking for leaks. Oil is running down tube that exits from lower left side of crankcase. Not the fitting, but what looks like a breather going towards airbox.
Un capped both accumulation lines that exit airbox (right side of bike) and they are dry.
Hopefully it's just an overfill?
ETA- While I have been putting on the miles, it has marking it's territory with a tiny quantity of oil, (like a drop a day) from the same location, but oil level checks always came out sound, so I chalked it up to an Italian bike. But this is a larger accumulation).
« Last Edit: September 27, 2016, 08:02:13 PM by hannibal smith »
Re: Just to clarify
« Reply #8 on: September 28, 2016, 06:53:08 PM »
Oil leak mystery solved!
Those thermal shielding sleeves are there for a reason!
Shield sleeve had slipped up, thus exposing the lower breather pipe. The exposed section is no longer pliable, glossy with heat damage and has multiple fine cracks. Leaking from the cracks. Simple as that.
Got to get another section (part no. 32159610) and re anchor shielding in the proper location, and it's fixed. Love a simple fix.
Offline BMCMOTO
Re: Just to clarify
« Reply #9 on: September 28, 2016, 10:08:14 PM »
You might want to check the line that enters the sump from the rear.  That line enters the sump under the oil level and will drip if the crimped hose end comes loose on the fitting.  I suspect that heat from the exhaust causes them to harden and shrink.  I replace them with automatic transmission hose and a fuel injection clamp at each end.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline BMCMOTO
Re: Just to clarify
« Reply #10 on: September 28, 2016, 10:15:37 PM »
Part #30 in this illustration.
http://www.thisoldtractor.com/mg_manuals/spare_parts_catalog_v7_special_stone_2012.pdf
Well that didn't work as I expected.  Page 37 is the one with the illustration.
Brian
« Last Edit: September 28, 2016, 10:18:18 PM by bmc5733946 »
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Re: Just to clarify
« Reply #11 on: September 29, 2016, 10:08:29 AM »
Brian
Yep! Thanks!
Part will take at least a week and a half from Harper's- Im going to make my own fitting/assembly.
Offline BMCMOTO
Re: Just to clarify
« Reply #12 on: September 29, 2016, 05:10:44 PM »
I used a grinder to remove the crimp and a fuel injection hose clamp on each end of the automatic transmission hose, any auto parts store.  I also replaced the aluminum washer the is under the fitting.  Remember that the fitting hole is under the oil level in the sump, you will lose oil from that hole when you remove hose or fitting.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
