Author Topic: Valve stem  (Read 2064 times)
Offline creaky99
Valve stem
« on: October 07, 2016, 08:59:30 AM »
I am having trouble getting air into both tires. The air goes in, but very slowly. I had a rear flat Tuesday on a ride into KY, tried fix-a-flat, screwed on the nozzle, couldn't get any flow into the tire. Is there something odd/different about these valve stems?
Once you go over the hill, you pick up speed!
'98 Moto Guzzi EV11
Re: Valve stem
« Reply #1 on: October 07, 2016, 09:10:45 AM »
They are not all made the same, some have a long spring and a different bonnet than others. The problem seems that on some the air nozzle on the hose will seal against the outer of the stem before the pin is pressed down very far or the spring rate is less.  Go to an auto store and buy some different ones. Take the one out of the stem and take it w/you to compare.
Re: Valve stem
« Reply #2 on: October 07, 2016, 09:10:59 AM »
Quote from: creaky99 on Today at 09:59:30 AM
No.
If it is a used bike, you didn't say, someone may have messed with it.
« Last Edit: October 07, 2016, 10:52:22 AM by Wayne Orwig »
Re: Valve stem
« Reply #3 on: October 07, 2016, 10:50:29 AM »
No.
If it is a used bike, you didn't say, someone may have massed with it.
That would make the bike heavier, but shouldn't affect the air flow ... ?
Offline creaky99
Re: Valve stem
« Reply #4 on: October 07, 2016, 11:19:49 AM »
"The problem seems that on some the air nozzle on the hose will seal against the outer of the stem before the pin is pressed down very far or the spring rate is less.  Go to an auto store and buy some different ones. Take the one out of the stem and take it w/you to compare."
I think this is most likely the problem. I'll try to get longer valve cores. Thanks.
'98 Moto Guzzi EV11
Hymes Inc.
Re: Valve stem
« Reply #5 on: October 07, 2016, 01:14:03 PM »
  :thumb: lol
