1400 Eldorado Helmet Lock??
Topic: 1400 Eldorado Helmet Lock?? (Read 1865 times)
elvisboy77
November 15, 2016, 05:38:23 AM »
Any Eldorado (or other 1400 owners) find and use a helmet lock on the bike?
There is no mention in the manual, but there is a hairpin of pretty sturdy construction on the left side frame, just above the rear shock, under the seat. Is that a helmet lock?
Any input appreciated!
tris
Re: 1400 Eldorado Helmet Lock??
Reply #1 on:
November 15, 2016, 06:23:17 AM »
I'm not sure if this helps, but do you have a strange little double ended cable in the tool kit?
The CARC bikes came with a Helmet Lock Cable (AP8102502)
http://www.stein-dinse.biz/Complete-partlist/Unsorted/Security-helmet-fixing-cable::167164.html?language=en
Its designed to pick up on a "hairpin" under the seat and unless you use it you can't get a standard helmet attached to the bike.
I kept looking at this strange little cable as it doesn't look like it should be part of the bike for months before I worked it out
1995 Cali 1100 - carby "Dino" -now sold
1993 TW125 "POS" - Resting
elvisboy77
Reply #2 on:
November 15, 2016, 06:50:22 AM »
Hmmmm none in my little tool bag but I wonder if that isn't what was intended. What you say makes perfect sense. Thanks for the reply!
Uss
New Egg
Reply #3 on:
November 16, 2016, 12:05:00 AM »
No cable in my tool kit either......plus in the absence of a pivot up seat mechanism it is a real cumbersome exercise to lock in the helmet there. One would have to put the helmet down, then remove the seat and put that somewhere (probably on the ground) then loop the cable through the helmet and onto that hook and place the seat back. The reverse when you ride again. Not practical at all. It would have helped if the seat was on a pivot/support.......
