Author Topic: Someone please save this Convert ebay  (Read 4481 times)
Offline giusto
  • Giusto il canne del Como
    • photobucket
« on: November 26, 2016, 06:57:49 AM »
Someone pleaae save this Convert.
I have to believe it will go cheap...and this could be a good running and goid looking motorcycle with some attention to details.... Right now SHE has been beaten with the ugly stick.
Ask him if he still has any of the parts he took off of her.
http://r.ebay.com/zbSGu6
http://rover.ebay.com/rover/0/e11021.m43.l3160/7?euid=b5699a4226bc49b79a1bf606bd00c0f9&bu=43187436314&loc=http%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F252653548871&exe=15080&ext=38986&sojTags=exe=exe,ext=ext,bu=bu
 Or if the link doesn't work search 1976 Moto Guzzi 1000 Convert on eBay
« Last Edit: November 26, 2016, 07:02:21 AM by giusto »
2020 V 85 TT Travel
76 V1000 Convert Mr. Slate
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
Re: Someone please save this Convert ebay
« Reply #1 on: November 26, 2016, 07:42:47 AM »
UM, no thanks..
Offline chuck peterson
« Reply #2 on: November 26, 2016, 09:18:29 AM »
don't worry he has much further to go...not enough rust yet, needs to put it back out in the swamp
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline NC Steve
« Reply #3 on: November 26, 2016, 09:43:32 AM »
Oh I don't know, I think the thing could be a hoot to own and drive.
The vastly upgraded front end and brakes would be worth quite a lot in themselves, and it reads like the seller has done quite a bit of other work to it.
Just fiddle with the wiring a bit, add in a starter switch, and get some Vapor gauges, or use a GPS, it would be less expensive.
And the seller does say it has a clean title, and is currently registered and insured, all of which adds value.
If it was local and could be had in the $1K - $1200 range, I'd definitely want to check it out.
« Last Edit: November 26, 2016, 09:48:09 AM by NC Steve »
'16 Triumph T100
Past:
'19 RE Himalayan
'07 Honda ST1300
Mark Twain
Offline giusto
    • photobucket
« Reply #4 on: November 26, 2016, 04:30:50 PM »
agreed...if I were closer and the price right...800-1000 I think it would be a fun project.
They are a blast to drive...great around town/traffic bike....very comfortable ride
I did ask the seller if he had the parts he changed...pretty much no
2020 V 85 TT Travel
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
« Reply #5 on: November 26, 2016, 05:07:00 PM »
 What's up with that Buck Rogers headlight  :shocked:
Offline lti_57
  • Directly above the center of the Earth
« Reply #6 on: November 26, 2016, 05:07:25 PM »
Oh yeah I concur, 500 bucks. Especially if you had, this Vintage bike in your garage. This is a smoking deal, Maybe even 600 dollars   :cheesy:
I would bomb around on it, Till i got the parts to make it proper
2007 Guzzi Griso
1992 BMW K75
Offline Yeahoo Whoyah
« Reply #7 on: November 26, 2016, 05:43:57 PM »
From the add:
The clutch is removed. It have never used it. When is is cold I start the bike on the center stand but after the first start I start the bike just sitting on it.
I'm not very familiar with the Convert models.  Doesn't the owner mean he removed the clutch lever and cable? I thought the Convert two speed transmission propels the bike through a traditional multi-plate motorcycle clutch.
Greg Tillitson
El Dorado Hills Calif.
« Reply #8 on: November 26, 2016, 08:29:05 PM »
You can still ride a Convert with a non-working clutch.  The bike has a torque convertor.  It's not a true automatic transmission.  When you start the bike you have to make sure that you have the foot brake pedal is depressed otherwise it'll jump forward when the engine fires.
« Reply #9 on: November 26, 2016, 08:31:03 PM »
"Paging Rich A....Rich A to the white courtesy phone!!"    He's in the Santa Fe area.  :tongue:
Offline giusto
    • photobucket
« Reply #10 on: November 26, 2016, 08:37:25 PM »
Foot brake depressed, hand brake depressed, kickstand down and stand brake employed :)
Tork Converter...:) hence the name
 :popcorn:
2020 V 85 TT Travel
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
Online rodekyll
« Reply #11 on: November 26, 2016, 09:40:35 PM »
Mine has no clutch control.  j start it on the side stand with the front brake engaged.  Once started it idles on the side stand without trying to walk away.  The torque converter is ineffective below about 1000 rpm.
Offline John Ulrich
« Reply #12 on: November 26, 2016, 10:31:37 PM »
Where's Rich, that's in his backyard!
Eagan, MN & Scottsdale, AZ
MN MGNOC Rep  L#800
« Reply #13 on: November 27, 2016, 12:06:49 AM »
He needs to answer the courtesy phone. :popcorn:
Offline Turin
« Reply #14 on: November 27, 2016, 11:58:51 AM »
This thing looks scary. How will it handle with decent tires? 16" Yamaha cast wheel and a stock borrani rear is an odd combo. Is an old 80's non adjustable fork and brakes from a tariff beater FZ700 an upgrade?
1985 Sidlow Guzzi
