What do you do about the longer steering stem? cut new threads? add spacers? use roller bearing adapters? something I've not thought of?
Does the fairing bracket fit over the larger fork tubes? it looks like it might.
Does the wider fork spacing cause the handlebar controls to interfere with the trailing edge of the fairing? In other words, is a different fairing bracket required?
Anything else that needs considering with the fairing and triple clamps?
Thanks,
Shawn
