Bikes are shipped oiled up but of course with the Nuovo Six Speed in the V7-II there is no way of actually checking the level. As for what oil? You can bust a gut going for the AGIP stuff if you wish but any decent, fully synthetic, 75/90 is more than adequate...
After the first change, the manual states every 37,300 miles for the gearbox
for real?
Page 48/280 in the manual: 60,000 kilometers
I am considering Castrol Edge 10W-60 for the engine. Been using Castrol for every bike since 1963, other than the two Sportsters (and could/should have used it for them).
The oil that is specified by Motio Guzzi for the 6-sp small block gearboxes is also used in heavy duty truck and bus gearboxes that are normally serviced every 500,000 mi. But, bear in mind that this oil, eni ROTRA LSX 75W-90, is not quite the same as the very similar one that AF1 and others sell in the US. It is rated API MT-1, in addition to GL-4 and GL-5. The MT-1 rating is supposed to increase the life of the oil and the seals. Since this oil in not available from the US distributor in 1-L bottles, I got mine directly from an Italian seller on ebay. It is expensive to ship, but I'm not worried, since I'll use only 1 L every 120,000 km. If I were to instead use the oil that IS available in the US, I'd probably change it more often than every 60,000 km.
At the risk of encouraging yet another oil thread, let me just point out that Castrol Edge 10W-60 is a fine oil for it's intended uses, and carries an API certification of SN. The oil specified by Moto Guzzi, eni i-Ride MotoGP 10W-60, carries an API certification of SG. The difference? SG oil contains significantly more of the anti-wear agent ZDDP than SN oil. Why doesn't Castrol put more ZDDP in their oil? ZDDP does a great job to lengthen flat tappet life but its by-products degrade exhaust catalytic converters faster. It's been reported that US auto industry and EPA have exerted pressure on the oil manufacturers to lower the amount of ZDDP they put in their oils.Now, I'm not saying that SG oil will prevent all wear and SN oil will not. If you put less than 25,000 mi on your motorcycle before you sell it, you probably wouldn't notice any difference. But, I'm planning to keep my V7II longer, so I'm sticking with what Moto Guzzi recommends.
Most M/C manuals suggest SG, but most M/C have a wet clutch, thus the oft stated reason for suggesting/specifying an obsolete grade.
....However, since the 6 speed, as is most M/C, is synchronized....
