If you haven't upgraded the charging system you might want to keep a eye on the battery charge level...
T3 has a 20A charging system...T has a 14A system
IIRC the upgrade rotor is a larger diameter (maybe 73mm v 75mm?) and the later stator has a spader blader at the "Y" lug. (sorry, couldn't help myself ) That's from ancient memory though, don't hold me to it.But to maybe steer you clear of trouble -- One of the annoying things about the LED and HID spec sheets is that they don't measure stuff consistently, or the way you'd expect. You can see that by browsing the lighting aisle of the local Home Depot -- claims of lumens v consumption are all over the board because they aren't all measuring things the same way. It makes accurately calculating your total energy load a challenge, but it's important if you've got an anemic charging system such as the bosch.Is the 20w total system draw (dies + all that other stuff hanging off it), or is it the draw of just the dies? Some marketing specs are deceptive about total system load to appear competitive. Also, does the load remain the same draw for both low and high beam? My LED adds dies to the array to make high beams = 100% more draw. . . . and then there's the rpm you need to maintain to wring the blood out of the turnip. . .
The alternator in my 1990 Cali III is getting weak from age. You have to spend hours on the hiway in 4th gear to recharge the battery. But I have the Saprisa alternator. Not sure of that kit will fit!
In my experience the ignition system draws at least 6 amps, a 55w headlight about 4a. You may be feeding only 2a thru the LED headlamp but even so with a 14a alternator the charging system will have to be in top shape to keep the battery strong if you're pulling 3a through a heating system. One advantage of the T is that you can switch off the headlight when you don't need it.I put the same grip-heaters on the Mille. The Saprisa alternator at a nominal 20a barely keeps up at 3000 rpm and no hope idling around town. I haven't yet found an LED bulb that will fit in the shallow Mille shell, but I can retire that shell when I mount the SP fairing.And I recommend the EME upgrades. They worked well on my T.
Due to a wonky Yamaha switch I have it wired always on. Besides here you have to burn the headlight at all times.As long as the output of the alternator matches exceeds the load it should be fine, right?
I think this one will work, best to call Euro motoelectric,https://www.euromotoelectrics.com/product-p/edl450-altkit105.htm
