Author Topic: 08 Norge final drive  (Read 2144 times)
Offline Scott of the Sahara
« on: April 13, 2017, 11:32:41 AM »
Is there a replacement final drive that is lower geared for the 08 Norge?
Re: 08 Norge final drive
« Reply #1 on: April 13, 2017, 01:43:44 PM »
No.
Offline Huzo
« Reply #2 on: April 14, 2017, 05:45:46 AM »
What do you find about the standard ratio that you want to change ?
« Reply #3 on: April 14, 2017, 08:31:57 AM »
I sometimes think about adding a sidecar, and it would work much better with lower gearing.
The bike is geared perfect for solo riding, but I rarely use 6th gear, since I am not using the freeways much. I would trade 6th for a granny 1st.
Offline drdwb
    • backfeelsgreat.com
« Reply #4 on: April 14, 2017, 10:35:40 AM »
Go find a Cal EV 02, drop a 7/33 rear end in it, swap the front end for a leading link set up and than mount your hack on it. That way you get a bike that's safe and can handle the load,without buggering up the sport ride of the Norge. Just my opinion.
« Reply #5 on: April 14, 2017, 05:19:19 PM »
I'd second this advice. The CARC bikes make lousy sidecar tugs. Not only do they not have a frame cradle for the lower front mount but the swingarm bearings are inboard of the swingarm so the moment on them is much higher than it is on something *Conventional* like a Cali.
My mate Peter from Townsville has a great outfit built onto a Hydro Cali, it's a joy to drive, adjustable links, 15" rims all round with car tyres. Its like its got power steering and tracks beautifully. Like most Calis of that period though it needs a new fifth gear....
