I have yet to find a grease that stays in place and prevents rust.
Totally missed that grub screw!! Thanks for that! See that's why you ask before using hammers I have the moly grease Honda use for my CX500. It's for splines and high pressure/shear use. So I'll use that. It's quite thick and sticky Thanks guys!
If you mean the Honda Moly 60 paste, it doesn't do a thing to slow the rust. I didn't have much luck with it alone.
The coupler, #12, should slide right off the back of the driveshaft.I have had it freeze onto the back of my 2004 EV a few times. I soak it for DAYS in penetrating oil. I made a hook that I hook onto it. And I try to get it hot. It takes a lot of work but it eventually comes out.I have yet to find a grease that stays in place and prevents rust.
