I am trying to out what frames might be the same as my 1993 1000S. It has Tarozzi rear sets and I want to put it back to the normal footrests, pegs, shifter, brake pedal. The parts are hard to find for a 1000S but I think the frame is probably the same as other bikes so it might widen my search.
Peter, 1000S and LeMans 1000 were identical under the skin.I would think that foot pegs and levers from any LeMans 1000 would fit right and look right.
PIA, bland, boring junk
Just a guess but.....try the Strada and SPIIIThey look very close.Looks like you may also have to screw with the exhaust mounts.Paul
I just posted a reply but it didn't go through. I will try again. Thank you guys. I think you are exactly right.. the LM1000 is the same. Harpers told me that there is a very slim chance of finding anything because they all broke when they even came close to the ground. How about forgetting the passenger pegs and those cast brackets. Would 850 levers and pegs fit? Thanks Groover for the kind offer. If I can't find anything I will send the bike and title to you in boxes. I will send you this PIA, bland, boring junk too, if you have room.
Hi, I am trying to out what frames might be the same as my 1993 1000S. It has Tarozzi rear sets and I want to put it back to the normal footrests, pegs, shifter, brake pedal. The parts are hard to find for a 1000S but I think the frame is probably the same as other bikes so it might widen my search. I am hoping the parts may be around because so many people switch to rear sets but maybe that is wishful thinking. I truly appreciate any advise or leads. Many Thanks, Peter
