Author Topic: what motor is this in my 850-t?  (Read 2275 times)
Offline troyhamilton
  • Dr frankie
« on: July 20, 2017, 12:05:47 PM »
I was told it was a 850 motor with a big bore kit? not sure. according to my freind at the machine shop the bore is 3.462 or 84 mm and the bottom bore is close to 88 mm.  or  3.4646 reason im asking is i need a cyl due to rust from getting water inside and ruining the cyl. engine is stamped vc 092410 looks factory. thanks
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
we need a tech section!
  • Dr frankie
Re: what motor is this in my 850-t?
« Reply #1 on: July 20, 2017, 12:13:38 PM »
ok i looked at the frame, thats my vin original motor...
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
  • Dr frankie
« Reply #2 on: July 20, 2017, 12:47:30 PM »
the 88 mm is the outer diamitor. sorry about that. was on the phone and I mis typed!
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline twhitaker
« Reply #3 on: July 20, 2017, 03:01:27 PM »
Those are likely G5 or Convert cylinders.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
« Reply #4 on: July 20, 2017, 03:53:49 PM »
Convert/G5/SP/CX100 cylinders are 88 mm inner diameter.
  • Dr frankie
« Reply #5 on: July 20, 2017, 04:04:02 PM »
yeah, im just wanting to know what replacement parts i need to repair it. bike had 91,000 miles on it. has a burnt valve. havent took the other head off.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
« Reply #6 on: July 20, 2017, 04:43:03 PM »
At 91,000 miles it'll need the sludge trap cleaning out and quite likely a crank grind. Barrels and pistons, tappets, maybe a cam, cam retainer plate, valves, seals and gaskets. My guess is there won't be much of the original engine left by the time you've fixed it.
  • Dr frankie
« Reply #7 on: July 20, 2017, 06:14:25 PM »
Pete you sure know how to make a grown man cry....
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
« Reply #8 on: July 20, 2017, 09:00:01 PM »
Troy, if it's got Nicasil bores they'll probably be fine. It's the crap in the sludge trap and more importantly the crap it hasn't caught that will of caused the bearing damage.
  • Dr frankie
« Reply #9 on: July 21, 2017, 05:08:02 PM »
its a sideline redo right now
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
Offline Denis
« Reply #10 on: July 21, 2017, 08:25:35 PM »
You can get the cylinders resleeved.
'87 SPII
'74 Eldorado
'85 LeMans
'91 California big valve
'61 Falcone Turismo,
'41 Indian 841
'40 Indian Model 640B ex-Canadian Army
'40 Indian Chief 340B
  • Dr frankie
« Reply #11 on: July 21, 2017, 09:27:57 PM »
they have damage from water itting in the cyl and rusting. on the swap meet  theres a set of cyls and a cyl with a piston. id take a picture but i broke my camera.
Dr Frankie!
1967 v7, gone
heldorado, gone
1975 850-t gone
1974 850-t gone.
2002 Jackal!
