Author Topic: Baxley vs Condor: opinions  (Read 5046 times)
Offline kidsmoke
« on: August 22, 2017, 02:14:46 PM »
looking to purchase one of these. Both I'm certain do the job well. Both are MADE IN USA, and pretty pricey relative to their Harbor freight type competitors. I've come to peace with that.
Condor: less expensive than Baxley, folds down when necessary
Baxley: has a nice lock feature when loaded, prevents pivot from from pivoting.
Any reason to buy one and not the other?
Leaning Baxley.
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
Offline Demar
Re: Baxley vs Condor: opinions
« Reply #1 on: August 22, 2017, 02:20:10 PM »
Leaning Baxley.
I have a Condor and it works very well. Holds the Stelvio securely. I don't have any experience with the Baxley.
2012 MG Stelvio NTX
2010 Bonneville T100
1953 Galletto 175
Offline pyoungbl
« Reply #2 on: August 22, 2017, 03:03:47 PM »
I have been using the Baxley for over 10 years.  Mine does duty both in the garage and in my trailer, absolutely no complaints (other than I wish I had bought it earlier).  Mine has a feature to change the width of the tire clamp as the whole clamp rotates fwd.  It is also very secure on a concrete floor, thanks to the rubber pads.  When using this on the trailer I drop large nails (spikes) down through pre-drilled holes in the trailer bed so the chock cannot walk around while underway.  Condor probably has all these features.  The one drawback to my Baxley is that it is steel and now shows some signs of rust around pivot points.
Peter Y.
'13 V7 Special (red/white)
« Reply #3 on: August 22, 2017, 03:12:49 PM »
You never lose buying quality the first time.  Purchase one time and be done.
Offline Socalrob
« Reply #4 on: August 22, 2017, 03:19:39 PM »
From an old surveyor's equipment catalog from the 1880's:
“The Bitterness of Poor Quality remains Long after the Sweetness of Low Price is Forgotten"
Offline Socalrob
« Reply #5 on: August 22, 2017, 03:29:19 PM »
"The Bitterness of Poor Quality remains Long after the Sweetness of Low Price is Forgotten"
Offline kidsmoke
« Reply #6 on: August 22, 2017, 03:47:03 PM »
Peter Y.
got a bit of time in on you tube. In reply to whats red ^^, nope. The Baxley increasingly clamps the tire as it pivots (blue ^^). The condor is just a static cradle. That seals it in my view. Great feature
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
Offline decotriumph
« Reply #7 on: August 22, 2017, 04:43:20 PM »
Never used a Condor. have a Baxley and love it. had a HF one and gave it away to get rid of it.
Alan M
Tullahoma, TN
2017 V9 Bobber
1999 Excelsior-Henderson Super-X
1972 Suzuki GT550J Indy
1966 Honda CB160
Past Guzzis:
2020 V85TT Adventure
2017 V9 Bobber
2014 Stelvio NTX
2012 Stelvio
2004 California Touring (x2)
2000 Jackal
1997 1100i Sport
1984 850-T5
1975 850T
Offline Ralph Plant
« Reply #8 on: August 22, 2017, 05:08:37 PM »
I have a Baxley mounted on my HF table..works a treat. Not cheap but I can ride up on the table and walk away..no drama..quality design and construction.
Ralph Plant
Tiverton, RI
'78 LeMans
« Reply #9 on: August 22, 2017, 06:20:30 PM »
I have a Condor in the Transit van. It's adjustable for wheel size. I've traveled many thousands of miles with a bike in a van. Unlike some, the Condor is totally solid.. never a movement. I think (hope) we could roll inverted and the bike would still be there.  :smiley:
Offline kidsmoke
« Reply #10 on: August 23, 2017, 08:50:07 AM »
Scha-wiiing!
Craigslist score on a Baxley. Done.
Thanks for the feedback lads.
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
« Reply #11 on: August 23, 2017, 09:59:46 AM »
Attaboy.  :smiley:
« Reply #12 on: August 23, 2017, 10:08:46 AM »
I have a Condor, and it works the same way the Baxley works.   It's NOT just a static cradle - the weight of the bike works on the pivot to "increasingly clamp the tire as it pivots".
I can roll my 580 pound Stelvio or 650 pound Triumph into it, let go and walk away.
Just wanted to set the record straight.
Offline kidsmoke
« Reply #13 on: August 23, 2017, 10:17:11 AM »
How is this possible Lannis? Look at the cradle itself, the part that pivots 'over center', it is a single piece of stamped metal. There are no hinges or movable pieces. what clamps on the tire? That same portion of the Baxley is two separate pieces of metal which, as they pivot from 'un loaded' to 'loaded' get closer together, actually squeezing or pinching the tire. How does a one piece stamping accomplish this?
« Last Edit: August 23, 2017, 10:20:58 AM by kidsmoke »
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
« Reply #14 on: August 23, 2017, 10:43:15 AM »
The "cradle" clamp is welded to the pivot pin (the pivot pin is adjustable to any of the six holes that you see there, to handle anything from little to big wheels).    As you roll the bike onto the cradle, the cradle pivots around on the pin (in the direction of the bike's motion, about 90 degrees total) until the wheel is pressed up against the front, upright, fixed part in the front, and held against it by the pressure of the cradle from the back, supplied by the bike's weight.
Believe me, I use it every day.   I've never used a Baxley, but it looks like it works exactly the same.
« Last Edit: August 23, 2017, 10:47:35 AM by Lannis »
Offline kidsmoke
« Reply #15 on: August 23, 2017, 10:49:24 AM »
The "cradle" clamp is welded to the pivot pin (the pivot pin is adjustable to any of the six holes that you see there, to handle anything from little to big wheels).    As you roll the bike onto the cradle, the crade pivots around on the pin until the wheel is pressed up against the front, upright, fixed part in the front, and held against it by the pressure of the cradle from the back, supplied by the bike's weight.
they do work the same, but, IN ADDITION to doing exactly what you describe, the Baxley cradle is a two piece mechanism which pinches the tire. STATIC was the wrong term, for sure. But the Baxley adds an additional holding function. Probably not tremendously significant, but it is additional clamp force on the tire/wheel. Not trying to be a dick, just since the particular differences are being called out, it's worth being precise. No doubt they are both excellent in quality and function.
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
« Reply #16 on: August 23, 2017, 11:05:46 AM »
No, I see what you're talking about.   I'd only ever seen the Baxley Sport Chock, which does work exactly like the Condor.
The Baxley Trailer Chock has that extra "pinching" motion for the sides of the tire.
Like someone said, though, you almost can't push a bike sideways out of the Condor chock if you try .... and at $139 and free shipping, it meets that Guzzi buyer goal too!
Offline Mr Pootle
« Reply #17 on: August 23, 2017, 11:34:25 AM »
Ah, now I've got to Lannis's post I understand. It's one of those threads the title of which puzzles us from Europe. I knew Condor as a pipe tobacco, and thought that Baxley would be too. I was looking forward to tales of when smoking a pipe was something everyone tried at some point.
« Reply #18 on: August 23, 2017, 11:48:01 AM »
Lannis and Baxley aren't very common, but sometimes they come together ....
https://georgia.arrests.org/Arrests/Lannis_Baxley_7113435/
I'm going to have to get me one of those chocks now.
Offline SemperVee
  • USMC Retired
« Reply #19 on: August 23, 2017, 12:02:16 PM »
  I have the ride into and step off Condor also. Very happy with it.  I use to keep my Victory straight up in the garage and has a useful trailer lock in farkle if needed.
53 years of Street Riding - All Brands
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Offline kidsmoke
« Reply #20 on: August 23, 2017, 12:59:19 PM »
that's kinda funny.
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
Offline kidsmoke
« Reply #21 on: August 23, 2017, 01:08:11 PM »
The Baxley Sport does it as well.
check this video. Go ahead and jump to the 1:00 min mark.
https://youtu.be/I0ukZGXn9GU
'79 G5      (Gina)
'93 1000S (Monica)
'09 GRiSO  (Perla)
